Arcing Brushes - Router Forums
 2Likes
  • 1 Post By Stick486
  • 1 Post By Cherryville Chuck
post #1 of 7 (permalink) Old 01-04-2016, 11:19 AM Thread Starter
Default Arcing Brushes
I have a relatively new Porter Cable plunge router that was losing power under modest load with a lot of accompanying brush arcing. I pulled the brushes and they were badly chipped. I replaced them and ran the router under moderate load for about 1 minute and the arcing started over again. I pulled the brushes after just that single 1-minute run and the new brushes were badly chipped. Is there a "home fix" for this? Other suggestions? Thank you!
paddler0124 is offline
post #2 of 7 (permalink) Old 01-04-2016, 11:41 AM
get it warrantied...
you have bigger issues...
bad bearing, out of balance/damaged armature...
neville9999 likes this.
post #3 of 7 (permalink) Old 01-04-2016, 12:21 PM
I would also say it is a manufacturing defect. I would guess that maybe one of the commutator bars on the armature where the brushes make contact is higher than the others.
swarfmaker likes this.
post #4 of 7 (permalink) Old 01-04-2016, 12:51 PM
Nickp's Avatar
First Name: Nick
It's called C.A.S.B. - Commutator Anti-spherical Speed Bump...
Commutator has some damage...yes...bring it back...you will otherwise be dealing with it till you throw it out...
If you can't take it back, you will need to get it on a metal lathe to smooth the commutator...if there's a bad pole.
If you spin the shaft by hand, with the brushes installed, do you feel some un-evenness...?
You might also check the spring and wire to make sure it allows plenty of pressure and travel for the brushes to ride on the commutator... (so they don't float)
Is the commutator clean...? All that arcing and sparking may have left some carbon residue on the commutator.
Again, if you can't take it back...check the radius of the brush as compared to the commutator...maybe it's too acute and the edges are catching the edges of the poles...? Right brushes...?
Of course, the first choice is take it back...
Nick
Nickp is offline
post #5 of 7 (permalink) Old 01-04-2016, 01:03 PM
is this a trend???
Router Forums - View Single Post - Dewalt DW618 noised motor and almost no power
post #6 of 7 (permalink) Old 01-05-2016, 10:39 AM
TenGees's Avatar
First Name: Paul
Like the others said: warranty first.
In the past on several motors (not on a router, yet) I have found that if the brushes were arcing for a while, it will damage the comm. I have successfully sanded the surface on several motors. On some I used the GF's fingernail-sanding emory boards. I wouldn't do this operation unless I thought it would turn out better than it is now, or on a warrantied item. If you do it, be careful not to hit the part where the wires attach to the comm and clean out any particles left from sanding. The emory board helps because it's flat. If you use only your finger with sandpaper you might put a curve in the surface. A small fine file might actually be better. Basically hold the the abrasive where the brushes would run and turn the shaft.
TenGees is online now
post #7 of 7 (permalink) Old 01-05-2016, 12:47 PM
Do the warrantee thing first and ask for a replacement. Send the brushes along with the unit. If they won't cover it, then try the suggested repairs. If you wait, you might easily run out the guarantee period and then its all your problem. My thought are that if you don't get a replacement, I predict the thing will find its way to the trash bin. Then you can get a Bosch.
DesertRatTom is online now
Motor trouble shooting Stick486 Tools and Woodworking 3 09-01-2016 08:39 PM
Router with Brushes, Single Speed mrmombo New Member Introductions 6 02-24-2014 08:26 AM
Stanley H39B Router Motor Brushes Burning Cookie Monster Tools and Woodworking 1 07-04-2011 11:15 AM
Stanley Trim Router - brushes rcsec Portable Routing 3 11-19-2009 07:05 PM
Glue Brushes Greeneyedeagle The Finishing Touch 13 03-28-2009 10:39 PM
