Pressure Switch - Router Forums
 2Likes
  • 1 Post By BrianS
  • 1 Post By Cherryville Chuck
post #1 of 10 (permalink) Old 05-04-2016, 08:25 PM Thread Starter
Default Pressure Switch
Is there anyone here can help me find a good Pressure Switch Control Valve for Air Compressor? I just saw in ebay AC 500V 175 PSI 4 for 21 bucks. I have no idea if it is a good deal. Can you suggest also a good brand/maker of pressure switch? Thanks!
tidyswoop is offline
post #2 of 10 (permalink) Old 05-04-2016, 08:46 PM
BrianS's Avatar
First Name: Brian
Have you checked with the manufacturer of your compressor for part availability?
No idea what type of compressor you have, but for the average home-use compressor, 175psi is a little on the high side IMHO.
Herb Stoops likes this.
Brian
(Origin uncertain)
BrianS is offline
post #3 of 10 (permalink) Old 05-04-2016, 10:10 PM
square D make some very good ones...
http://www.amazon.com/Square-FHG12J5.../dp/B000DCN8EA
post #4 of 10 (permalink) Old 05-04-2016, 11:31 PM
Second square D. Make sure it will handle the current draw for your machine and that it has the right cut in/ cut out range. Most air nailers and staplers work at 100psi or less depending on fastener length, so you want a cut in pressure at about that psi and 125 to 135 is more than adequate for woodworking needs. You don't want to run at pressures higher than you need because it just wears it out faster for no useful reason.
RÖENTGEEP likes this.
post #5 of 10 (permalink) Old 05-05-2016, 09:51 AM
schnewj's Avatar
I'll second the Square D. I always used them as replacements. They are easy to adjust the upper and lower pressures...they stay set.
Typically you will pay $20+ for one.
schnewj is offline
post #6 of 10 (permalink) Old 05-05-2016, 11:18 AM
thanks for the vote and good morning Snooge...
post #7 of 10 (permalink) Old 05-05-2016, 02:35 PM
schnewj's Avatar
It's MORNING! Where did the night go?
schnewj is offline
post #8 of 10 (permalink) Old 05-09-2016, 01:32 PM Thread Starter
I have a porter cable compressor and called them a few days ago but they don't have the pressure switch available.
175 IS a bit high. Just checked again and it just goes up to 150 PSI max (poor eyesight, sorry).
Will check square D but also looking at Dynapar's air compressor pressure switches for comparison. I'll let ya'll know which one I'll be getting..soon!
post #9 of 10 (permalink) Old 05-17-2016, 10:28 AM
Honored Member
harrysin's Avatar
First Name: Harry
You don't mention what the problem is with your pressure switch. Some time ago the air was leaking as fast as it pumped, seemingly from the pressure switch! I posted the following which may be of some help to you.
Router Forums - View Single Post - Recent problems with my compressor
Harry
harrysin is offline
post #10 of 10 (permalink) Old 05-17-2016, 10:35 AM
Honored Member
harrysin's Avatar
First Name: Harry
Here is a close-up of the offending valve which I didn't know existed!
Harry
harrysin is offline
Bosch 1617 switch repair reikimaster General Routing 37 06-18-2017 09:33 PM
Problem with NVR switch wiring tyro General Routing 10 04-15-2016 01:48 AM
Trouble with my Craftsman pressure washer George Kennedy Tools and Woodworking 6 02-28-2011 05:37 AM
Lean Managed Switch Question MrCapuchino General Routing 2 07-27-2010 09:55 AM
