Picture frame - Router Forums
 15Likes
  • 14 Post By kywoodchopper
  • 1 Post By DesertRatTom
post #1 of 9 (permalink) Old 11-05-2016, 11:47 AM Thread Starter
kywoodchopper's Avatar
First Name: malcolm
Default Picture frame
My sister-in-law asked me to frame a picture of her's and my wife's mom for my wife's birthday. Actually it was a rolled up picture / poster that was 20" by 30" that my brother-in-law had created. I took it to a frame shop to have a boarder made and to unroll and attach it to a cardboard backing.
I selected cherry for the frame and walnut for an inlay. I made the frames 3/4" thick by 2 1/8" wide.
I used the table saw with a 1/8" blade making multiple passes to cut groves in the cherry for installing the walnut splines. After gluing those in I finish planing the cherry and walnut to 3/4" thick.
I used a miter saw to cut the 45 degree corners and made a jig to allow micro adjusting the cutting the lengths. My micro adjuster is a wood screw inserted into a board for a stop (last photo).
I don't have a biscuit jointer or domino so I cut mortises in the corners using a jig that I made for this project. I cut those with a 5/16" spiral router bit using a plunge router.
I planed a small piece of cherry to use as floating tenons. I rounded the edges and cut to length.
I sanded the frames to 360 grit using a foam pad with an orbital sander.
To prevent glue squeeze out on the frame, I applied a couple coats of thinned shellac to the frames.
After gluing the floating tenons in the corners I used a belt clamp made by Wolfcraft to clamp the frame together.
I then sanded the frame and applied two more coats of thinned shellac then 4 or 5 coats of polyurethane thinned with mineral spirits. The shellac and poly finish were applied with a blue shop paper towel cut in 1/4 sheet then folded to about 2" by 2".
I then took the frame back to the frame shop to install glare proof glass and inset the picture along with the hook on the back.
Name:	Rough lumber for picture frame.jpg
Name:	Inlay and dados.jpg
Name:	Gluing walnut inlay into cherry frame.jpg
Name:	picture frames.jpg
Name:	jig for cutting mortises.jpg
Name:	Floating tenons.jpg
Name:	micro jig for cutting miters.jpg
kywoodchopper is offline
post #2 of 9 (permalink) Old 11-05-2016, 04:14 PM
Man, that's a nice frame. The inlay makes it special. I had a lot of trouble making frames well until I got a Grizzly miter trimmer. Now I just use splines to reinforce the corner. I like the look of a spline.
DesertRatTom is online now
post #3 of 9 (permalink) Old 11-05-2016, 05:05 PM
RainMan 2.0's Avatar
Wow Malcolm , I have to take note of how this was done . That looks incredible with the inlay look . Great job
And you made tenons , way above my capabilities
Ok ,I never insulate
RainMan 2.0 is online now
post #4 of 9 (permalink) Old 11-05-2016, 05:08 PM
Malcolm this is a beautiful picture frame but after seeing the beautiful boxes you make, I would expect no less.
billyjim is offline
post #5 of 9 (permalink) Old 11-05-2016, 06:58 PM
old55's Avatar
First Name: Ross
+1 what they all said.
Ross,
old55 is offline
post #6 of 9 (permalink) Old 11-05-2016, 09:33 PM
bryansong's Avatar
First Name: bryan
Malcome, that looks awesome!
bryansong is offline
post #7 of 9 (permalink) Old 11-06-2016, 06:28 AM Thread Starter
First Name: malcolm
For my wife's birthday I will probably make her a wooden basket. I know I had better get cracking on it. I'll post photos when done.
post #8 of 9 (permalink) Old 11-06-2016, 08:05 AM
First Name: Richard
+1 what they all said. I like it a lot.
Shop guy is offline
post #9 of 9 (permalink) Old 11-06-2016, 09:54 AM
What works for me is jewelry. Can't miss. Although she might really like a bundle of stretched canvases for her paintings.
This frame is really beautiful, modern looking while still having a classic feeling.
Roy Drake likes this.
How to Make a Picture Frame learnexperience Table-mounted Routing 10 09-24-2011 04:48 AM
How to Make a Decorative Picture Frame Using a Router learnexperience Tools and Woodworking 1 08-02-2011 11:47 PM
picture frame techniques reds_21 Tools and Woodworking 15 06-30-2009 04:43 PM
Welcome to "Show N' Tell" Mark Show N' Tell 0 08-17-2005 04:55 PM
