Picture frame - Router Forums
 2Likes
  • 2 Post By kywoodchopper
post #1 of 5 (permalink) Old 11-05-2016, 11:54 AM Thread Starter
kywoodchopper's Avatar
First Name: malcolm
Default Picture frame
My sister-in-law asked me to frame a picture of her's and my wife's mom for my wife's birthday. Actually it was a rolled up picture / poster that was 20" by 30" that my brother-in-law had created. I took it to a frame shop to have a boarder made and to unroll and attach it to a cardboard backing.
I selected cherry for the frame and walnut for an inlay. I made the frames 3/4" thick by 2 1/8" wide.
I used the table saw with a 1/8" blade making multiple passes in the cherry to cut a groove for installing the walnut splines. After gluing those in I finish planing the cherry and walnut to 3/4" thick.
I used a miter saw to cut the 45 degree corners and made a jig to allow micro adjusting the cutting the lengths. My micro adjuster is a wood screw inserted into a board for a stop (last photo).
I don't have a biscuit jointer or domino so I cut mortises in the corners using a jig that I made for this project. I cut those with a 5/16" spiral router bit using a plunge router.
I planed a small piece of cherry to use as floating tenons. I rounded the edges and cut to length.
I sanded the frames to 360 grit using a foam pad with an orbital sander.
To prevent glue squeeze out on the frame, I applied a couple coats of thinned shellac to the frames.
After gluing the floating tenons in the corners I used a belt clamp made by Wolfcraft to clamp the frame together.
I then sanded the frame and applied two more coats of thinned shellac then 4 or 5 coats of polyurethane thinned with mineral spirits. Both the shellac and poly finish were applied using the blue paper shop towel that I cut into 1/4 sheet then folded to abut 2" by 2".
I then took the frame back to the frame shop to install glare proof glass and inset the picture along with the hook on the back.
Roy Drake and spike1 like this.
kywoodchopper is offline
post #2 of 5 (permalink) Old 11-05-2016, 12:52 PM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Malcolm, I need a picture of it. I have just found a supply of cherry and walnut but dont know what the two together look like.
sunnybob is online now
post #3 of 5 (permalink) Old 11-06-2016, 06:24 AM Thread Starter
First Name: malcolm
Default picture frames
There were pictures attached. I'll send the entire message again today.
Malcolm / Kentucky USA
post #4 of 5 (permalink) Old 11-06-2016, 08:11 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I saw it, you must have posted the thread twice.
That combo looks great. I have to go get some cherry.
post #5 of 5 (permalink) Old 11-06-2016, 03:43 PM
First Name: Ed
Sounds good looking forward to the photo.
herrwood is offline
Picture frame kywoodchopper Project Plans and How To 8 11-06-2016 09:54 AM
How to Make a Decorative Picture Frame Using a Router learnexperience Tools and Woodworking 1 08-02-2011 11:47 PM
picture frame techniques reds_21 Tools and Woodworking 15 06-30-2009 04:43 PM
Welcome to "Show N' Tell" Mark Show N' Tell 0 08-17-2005 04:55 PM
