Tenon Length - Router Forums
 4Likes
  • 3 Post By Cherryville Chuck
  • 1 Post By Knothead47
post #1 of 5 (permalink) Old 11-08-2016, 04:32 PM Thread Starter
Seldonman's Avatar
Default Tenon Length
Hello again everyone,
I am now planning to build a desk for my Grand Daughter and I have attached the rough plan for this desk. I have no problem with the right side drawers and case but I am not sure about the rest of the joinery. I want to do mortise and tenon on the left side but I am having trouble with the tenon length. If I use a 3/8 thick tenon the rule of thumb says I should be about 1.5 inch long. If I mortise the 1.5 inch square leg 1.5 inch deep it will be a through tenon, which is not a problem until I come to the front and back and then the tenons would intersect, which can not work. Also, should I attempt to do a dove tail sliding joint to mate the runner up to the plywood case.
Thanks again for any advice you may give.
Jim
Seldonman is offline
post #2 of 5 (permalink) Old 11-08-2016, 04:51 PM
Honored Member
First Name: pat
Yes and this is typical.
Use hardware. An inside corner brace will make up for a compromised joint. However, that hardware has to be well
placed and drilled to hold fasteners well.
Quillman is offline
post #3 of 5 (permalink) Old 11-08-2016, 06:38 PM
One solution is to cut the tenons to 45* on the ends and have them butt together. That gives you the maximum length for both.
MEBCWD, Roy Drake and Herb Stoops like this.
post #4 of 5 (permalink) Old 11-08-2016, 06:55 PM
Beat me to it Chuck. Make the tenons both as long as it takes to make a 45 degree joint inside the mortise.
Like Pat says an angle corner block will help too.
Herb Stoops is online now
post #5 of 5 (permalink) Old 11-09-2016, 11:16 AM
Knothead47's Avatar
Not an expert here but looks like a great project. Funny how much we do for the grand-kids.
OPG3 likes this.
John T.
Knothead47 is offline
Trimming Tenon To Fit Mortise. Gaia Tools and Woodworking 16 07-22-2015 05:57 PM
Shank Length vs. Cutting Length (or carbide height) in Straight Bits xzJoel Router Bits - Types and Usage 4 05-12-2012 10:11 PM
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 09:42 PM
Guide bushing length crquack Guide Bushings and Templates 17 01-27-2010 06:06 AM
mortise & tenon jig yairfe Jigs and Fixtures 23 10-21-2009 05:49 PM
