Advice on end table top construction - Router Forums
 9Likes
post #1 of 11 (permalink) Old 02-12-2017, 09:39 PM Thread Starter
First Name: Jamie
Default Advice on end table top construction
I planned on making one end table from a plank of rosewood measuring 5.5"w by 40" long by 3/4" thick. I have now been ordered to make a matching set (by a higher power). The plan was to cut it in half so I would have a table top measuring 11" wide by 20" long. The picture shows the original planned glue up.
Went back to the wood supplier but this rosewood is a bit unique, nothing matches. I am thinking resaw it to 3/8" thick, attach the thick veneer to a substrate such as 3/8" maple. Will this top warp immediately or in the near future. Advice needed? Here is picture of the plank and the mock up of the end table. I am thinking the 30 degree edges will disguise the maple and there is white wood in this rosewood piece. I really don't want to veneer all the edges. The under shelf is 1/2" maple.
Hutzul and Roy Drake like this.
jemangin is offline
post #2 of 11 (permalink) Old 02-13-2017, 01:49 AM
That's hard to say for sure Jamie, it depends on the grain in the wood. One thing that helps prevent it is to groove the bottom side so that any tension has room to move without causing distortion. I would be equally as concerned about seasonal movement. Wood expands and contracts across its width with humidity changes and your design has to allow that to happen.
Roy Drake likes this.
post #3 of 11 (permalink) Old 02-13-2017, 01:49 AM
jj777746's Avatar
Hi Jamie,I'm not saying this isn't rosewood but it looks nothing like the rosewood I've seen before.Anyway if both your timbers are properly dried/seasoned they shouldn't warp but just make sure your substrate & thick veneers grains are in opposite directions before you glue. Jamesjj.
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is online now
post #4 of 11 (permalink) Old 02-13-2017, 02:41 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Plus 1 for questioning the type of wood. I use rosewood and buy it by the 8 ft plank and have never seen that contrast or figuring in anything in my local woodyard.
Once the type is confirmed, it would help to look up expansion rates for the 2 woods you plan to use. That would help stop the 2 from delaminating.
jj777746 likes this.
sunnybob is offline
post #5 of 11 (permalink) Old 02-13-2017, 06:41 AM
difalkner's Avatar
First Name: David
I have a small piece of Brazilian Rosewood and it looks like that. I'm building acoustic guitars and my take is that it's a shame to use Rosewood on a table top
Rogerdodge likes this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #6 of 11 (permalink) Old 02-13-2017, 11:37 AM
JFPNCM's Avatar
First Name: Jon
Looks like Indian Rosewood to me.
Jon
JFPNCM is offline
post #7 of 11 (permalink) Old 02-13-2017, 11:56 AM
MEBCWD's Avatar
I agree with it being Brazilian Rosewood, there are many rosewood species and they vary in color and grain patterns. BUT I have seen some really nice accent tables with a tops made from various Rosewoods and I think it was worth using it. Of course some of those tables were probably built using veneered panels.
MEBCWD is offline
post #8 of 11 (permalink) Old 02-13-2017, 12:10 PM
MEBCWD's Avatar
Jamie you might check and see if you can find it online at one of the many good lumber suppliers. It will probably be costly but might be worth it to match what you have.
One other thought is to use veneer like this Brazilian Rosewood Flat Cut Veneer Lot 6" x 112" 3 Sheets Per Lot - VeneerSupplies.com
TwoSkies57 and Roy Drake like this.
MEBCWD is offline
post #9 of 11 (permalink) Old 02-13-2017, 09:20 PM Thread Starter
First Name: Jamie
Windsor Plywood had it labelled rosewood santos. Thanks for the tips.
My musician brother in law gave me a stern lecture. He says the world supply of rosewood should be saved for guitar frets. I'll behave in the future.
difalkner and jj777746 like this.
jemangin is offline
post #10 of 11 (permalink) Old 02-14-2017, 02:27 AM
jj777746's Avatar
Rosewood santos,Brazilian Rosewood whatever,it looks nothing like the rosewood I know which is a red ish almost maroon colour.At least I now know there are different types all over.Jamesjj
Advice on Mounting New Incra Table Top Stargate Table-mounted Routing 20 06-22-2015 08:28 PM
Oak Park BYO table kit, mounting table top Reddart Starting Off 3 12-28-2008 01:11 PM
router table top delroy33 General Routing 18 07-30-2006 04:53 AM
Sold: Router Table or Table Top -Sam- Woodworking Classifieds 10 01-29-2005 09:15 PM
