A Simple Bench - Router Forums
 31Likes
post #1 of 15 (permalink) Old 03-20-2017, 10:45 PM Thread Starter
MT Stringer's Avatar
Default A Simple Bench
I made a bench for my step daughter to use in her guest bathroom. It was for her birthday, and a total surprise. She loves it.
It should come in handy for anyone dressing in the bathroom. The bench has a shelf where shoes can be placed and put on or taken off while sitting. I tried it out and it works as advertised!
She will apply the finish after she has had time to figure out how she wants it to look.
I have been asked if I would post the Sketchup file, so it is included with this post. Feel free to use it and build your own. Just remember to measure twice and cut once. If you look closely at my bench, you will see the top doesn't extend over each end. Yep, cut it too short!
I have also included some pictures that I took during the construction. Good luck. I hope you like the project and get some inspiration from it.
I used the following tools during the construction of the bench.
  • Pencil
  • Tape Measure
  • Table saw
  • Miter saw
  • Random orbital sander
  • Kreg pocket hole jig (K3 model)
  • Drill driver
  • 18 gauge brad nailer
  • Jig saw
For this project, I used the project panels sold at Lowe's Home Improvement Center. The panels come in various sizes up to 24 inches wide and 8 feet in length.
I began by cutting the two end pieces to size. After laying out the guides for the "legs", I cut the waste out with a jig saw.
Then I ripped and cut the pieces that would form the face frames. To cut the "legs", I measured 3 inches and 2 inches (see diagram) and drew the angle. Simply cut it off with the jig saw and you're done!
I made two frames from the pieces and assembled them with glue and pocket screws. This particular wood is soft, so I used the fine thread screws and carefully drove them. I have split some of the wood in the past with the coarse screws so I changed to the fine thread.
Note that I also drilled pocket holes so the top can be secured to the top rail on each side of the bench. No glue, just screws. You can also drill pocket holes in the top of each end if you like but I didn't on this build.
The dimensions don't show it in the file but I measured down 1 inch from the top of the bottom rail and installed a 3/4 x 3/4 inch ledger on all sides of the bench frame. The shelf sits on the ledger and is held in place with a few brad nails. No joinery involved at all.
To assemble the bench, the two face frames were glued and nailed to the ends. I assembled the bench upside down so all four pieces would register on the flat work table. As it turned out, the bench doesn't rock. I like that.
An important note to remember. Before attaching the top, insert the shelf. Then you can maneuver it around so the pocket screws can be driven into the top. There is no way to get the shelf in place with the top attached. After the top was attached, I shot a few brad nails into the shelf to keep it on place.
I rounded the four corners on the top with a 3/4 radius. A little touch up sanding to knock off all of the sharp edges and this project was complete.
Name:	2017-03-19 15.33.53.jpg
Name:	2017-03-19 13.20.10.jpg
Name:	2017-03-19 13.20.19.jpg
Name:	storageemulated0Androiddatacom.sec.imsservicefilesreceived_files20170319_133323_1489948422460.jpg
Name:	2017-03-18 20.11.01.jpg
Name:	2017-03-18 20.11.09.jpg
Name:	2017-03-18 20.54.40.jpg
Name:	2017-03-19 11.29.41.jpg
Name:	2017-03-18 20.54.52.jpg
Name:	2017-03-18 21.48.29.jpg
Name:	2017-03-19 11.39.02.jpg
Name:	2017-03-19 11.39.10.jpg
Name:	Bench Overview.jpg
Name:	Leg Detail.jpg
hilldh, JFPNCM, chessnut2 and 12 others like this.
MT Stringer is offline
post #2 of 15 (permalink) Old 03-21-2017, 12:38 AM
jj777746's Avatar
Hi Mike,I'm exhausted from just reading what you have done in the past 2 weeks.It's a credit to ya.Jamesjj777746
MT Stringer likes this.
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is online now
post #3 of 15 (permalink) Old 03-21-2017, 06:55 AM
TenGees's Avatar
First Name: Paul
Nice job, Mike. I could use one to set my tablet on, to watch TV in the bath.
TenGees is offline
post #4 of 15 (permalink) Old 03-21-2017, 07:45 AM
Stoneface's Avatar
First Name: Frank
Mike,
I like the simplicity of the design. Excellent work.
Frank
Frank
Stoneface is online now
post #5 of 15 (permalink) Old 03-21-2017, 09:03 AM
roofner's Avatar
First Name: Gary
Mike is that pine boards glued up?
roofner is offline
post #6 of 15 (permalink) Old 03-21-2017, 09:03 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Just be careful in there......
A U.K. man who was reportedly charging his iPhone while taking a bath accidentally electrocuted himself.
According to the Daily Mail, the incident occurred on December 11 when 32-year-old Richard Bull's wife found him in the bathtub with severe burns; he was pronounced dead at his home.
Officer Craig Pattison indicated to the West London Coroner's Court that suicide had initially been considered a possible cause, but, in his words, "...the cable wasn't near the bath, it had been run there to charge a mobile phone. The extension cable was on the floor and it appeared as though he had his phone charger on his chest and the part between the phone charger and the cable had made contact with the water."
Based on the victim's burn marks, assistant coroner Dr. Sean Cummings recently ruled the death an accident "occurring as a result of electrocution."
sunnybob is offline
post #7 of 15 (permalink) Old 03-21-2017, 09:56 AM
chessnut2's Avatar
Nice design, Mike. The miters on the inner edges of the feet really set it off.
chessnut2 is offline
post #8 of 15 (permalink) Old 03-21-2017, 11:41 AM
JFPNCM's Avatar
First Name: Jon
Excellent work as always. You are one very busy chap.
Jon
JFPNCM is offline
post #9 of 15 (permalink) Old 03-21-2017, 01:59 PM Thread Starter
Yes. Here are some pics.
Hope this helps.
Name:	2014-10-18 14.09.17.jpg
Name:	2014-10-18 14.09.35.jpg
hilldh and TenGees like this.
post #10 of 15 (permalink) Old 03-27-2017, 12:04 PM
TenGees's Avatar
First Name: Paul
A U.K. man who was reportedly charging his iPhone while taking a bath accidentally electrocuted himself....
I just use battery power. Definitely no power cords near water. I think the guys wife had it out for him.
TenGees is offline
Bench Dog BenchTop vs. The Super Bench, Bench Top Router Table emergencyshutdown Table-mounted Routing 8 11-14-2011 01:58 AM
Bench Dog 40-016 ProLift Max Dejure Tool Reviews 1 08-04-2009 04:26 AM
Bench Dog Files Chapter 11 Bankruptcy jennofarc Tools and Woodworking 12 11-18-2007 03:08 PM
Keep It Simple ??? Drugstore Cowboy Lobby 5 07-31-2007 10:01 AM
