Adjustable Bench Update - Router Forums
 26Likes
post #1 of 14 (permalink) Old 04-15-2017, 03:45 PM Thread Starter
Default Adjustable Bench Update
I was cleaning up my "Pictures" folders and came across these of the completed workbench - at least until I get another idea, maybe a different top? Easy enough to do as it's just screwed on from the bottom.
I made a cabinet to go in the opening on both sides of the lower section. The depth of the drawers was limited by the distance back to the scissor jack, but it gives me 6 drawers deep enough to hold all the little odds and ends that collect around the bench - tapes, pencils, utility knives, drill bits, etc. and has turned out to be very handy. Of course, it would be better if the bench was bigger but that's all the space I have.
The cabinet boxes and drawer fronts are Sande plywood from HD, the drawer parts are 1/2" luan plywood. I did go ahead and glue 3/16" oak strips on the edges of the drawers to protects them from dings and me from splinters.
kp91, JFPNCM, marecat3 and 9 others like this.
tomp913 is offline
post #2 of 14 (permalink) Old 04-15-2017, 04:24 PM
sweet...
tomp913 likes this.
post #3 of 14 (permalink) Old 04-15-2017, 09:25 PM
old55's Avatar
First Name: Ross
Very nice job, thanks.
tomp913 likes this.
Ross,
ĎMembers are requested to add a first name in their profile as we are a very friendly bunch here'.
old55 is offline
post #4 of 14 (permalink) Old 04-16-2017, 11:18 AM
First Name: Richard
Nice
tomp913 likes this.
Shop guy is offline
post #5 of 14 (permalink) Old 04-16-2017, 11:27 AM
Great job and idea, always can use more storage.
tomp913 likes this.
Herb Stoops is online now
post #6 of 14 (permalink) Old 04-16-2017, 10:57 PM
RainMan 2.0's Avatar
Good design and build there Tom . That's going to come in very handy
tomp913 likes this.
Ok ,I never insulate
RainMan 2.0 is online now
post #7 of 14 (permalink) Old 04-17-2017, 09:26 AM
First Name: Roy
Well thought out and nicely built.
Roy Drake is offline
post #8 of 14 (permalink) Old 04-17-2017, 01:20 PM
Tom, on the cabinet that holds the drawers , do you use glue to , or just pocket hole screws ?
I have to start using pocket holes more often . Normally I dado in a rabbet joint , but I'm liking the pocket holes every bit as much, and it's less work with less things to go wrong
post #9 of 14 (permalink) Old 04-17-2017, 03:45 PM Thread Starter
@RainMan 2.0
Rick,
I pretty much always use glue as well as the pocket screws but that's just me. For single small to medium cabinets, I think it's way quicker and easier, particularly if you're working by yourself. If I was making a bunch of cabinets, say a complete kitchen, I'd probably go with dadoes - once you have the parts cut out, it's way quicker to get set up and do all the rabbets and dadoes at one time.
I watch videos of people using pocket screws and just holding the two pieces by hand while they drive the screws but that doesn't work for me, the part always move - and in the direction of the screws. What I wind up doing is clamping a stop to the one part, butting the other up to it and driving the screws - this assures that the part is in the correct location and doesn't move. See the photos below for examples where I'm doing this; in the first photo, you can see the block clamped to the cabinet side and being used to locate the stretcher, and the glue squeezing out of the side of the joint. As much as I work like that, you'd think that I'd put a stop on the block to make it easier to line up.
One thing I found, and everyone is different, but I feel more comfortable setting the clutch on my driver relatively low and use a slow speed to drive the screws - this to prevent spinning them in the plywood. I then take a couple of minutes to double check the screws, hand tightening with a screwdriver if necessary - you can see the screwdriver in the last photo, although I've switched over to the Kobalt ratcheting driver sold by Lowes as it fits my hand better - but most of the screws are fine using the driver as you can tell by feel when the screw is tight.
There are probably still occasions where I might still go with rabbets and dadoes, depending on the application, but the assembly gets a little trickier if the cabinet is large - and you're working by yourself. When it was the two of us, most of the cabinets were dadoed and stapled - end faces got a decorative panel (door) applied or were just clamped, but that took time waiting for the glue to dry and used up clamps. And I find that using my cutting grid as an assembly "table" works well as that gives room to get the clamps on the assembly.
tomp913 is offline
post #10 of 14 (permalink) Old 04-17-2017, 04:08 PM
Thanks for the post Tom . I like your idea of clamping a piece of wood to hold things in place when your putting the screws in . I'm finding that I have overtightened a few , so now I start with a drill , but finish with a screw driver . Gives me a better feel , but I'm sure seasoned pocket hole pros would scoff at my idea lol.
I assumed you used glue , but couldn't see any excess . I'm not to good with the glue ups yet
A Simple Bench MT Stringer Project Plans and How To 14 04-12-2017 05:14 PM
Windows 10 install review kp91 Lobby 176 07-24-2016 09:45 AM
Windows 10 coming to your PC ... Stick486 Lobby 68 06-28-2016 10:43 PM
Bench Dog BenchTop vs. The Super Bench, Bench Top Router Table emergencyshutdown Table-mounted Routing 8 11-14-2011 01:58 AM
Bench Dog 40-016 ProLift Max Dejure Tool Reviews 1 08-04-2009 04:26 AM
