I have an idea for a project for lattice trim on my deck - Router Forums
 8Likes
  • 2 Post By roofner
  • 2 Post By Stick486
  • 3 Post By tomp913
  • 1 Post By chessnut2
post #1 of 8 (permalink) Old 04-22-2017, 11:59 PM Thread Starter
roofner's Avatar
First Name: Gary
Default I have an idea for a project for lattice trim on my deck
My idea is to use French cleats to make it easier to accesses storage space under my deck has anyone done a similar project. I store my pots and supplies for the winter. My system now uses sliding lattice panels. If you have I'd be interested seeing picture of ideas you may have.
chessnut2 and MYB506 like this.
roofner is offline
post #2 of 8 (permalink) Old 04-23-2017, 12:41 AM
no pictures but French cleats work but you will have to frame the panels so that they will handle the abuse w/o separating...
you can do the frame picture frame style or trim the perimeter w/ flat mounted 1x2's...
Shop guy and tomp913 like this.
post #3 of 8 (permalink) Old 04-23-2017, 08:38 AM Thread Starter
roofner's Avatar
First Name: Gary
Stick that's my general idea make a face frame sandwich the upper cleat and lower cleat on the back of the frame.
roofner is offline
post #4 of 8 (permalink) Old 04-23-2017, 08:42 AM
you sound like the man w/ the plan...
post #5 of 8 (permalink) Old 04-23-2017, 10:04 AM
The French cleat is a great idea, wish I'd thought about it when I did mine - taking it down every 2 -3 years to wash the (vinyl) lattice and power wash the deck is a major PITA because of the number of panels (3) and all the trim pieces and joiners. I have to stick little pieces of masking tape on the parts so I can get them all back in the same location. You can't tell from the photos, but the bottom piece - below the horizontal trim piece - is separate, added to minimize the gap at the bottom. This was done so I could use just two sheets rather than 3 with a lot of waste - the track saw came in real handy for cutting those narrow pieces off the sheet. With the French cleats, you're still going to have to attach the "frame" to the deck so it doesn't blow off in a high wind.
harrysin, chessnut2 and TenGees like this.
tomp913 is offline
post #6 of 8 (permalink) Old 04-23-2017, 11:16 AM
chessnut2's Avatar
This is such a good idea! Being the unimaginative sort, I'd never thought about using french cleats for anything besides hanging tools in the workshop, and hanging heavy picture frames. Good luck, and we'd like to see some pictures of your progress.
Roy Drake likes this.
chessnut2 is offline
post #7 of 8 (permalink) Old 04-24-2017, 11:32 PM Thread Starter
roofner's Avatar
First Name: Gary
I'm running into a problem since deck is already built and this is a modification. The cleat would bring me out past ledger board. Putting piece under ledger board would bring me out past the lip of deck boards.
roofner is offline
post #8 of 8 (permalink) Old 04-25-2017, 05:18 AM
First Name: Mark
Can you screw a 2 X on edge under the deck boards then add another deck board on top of this around the deck like a picture frame?
MYB506 is offline
Project idea for carvers Mike Pyrography and Carving 2 07-15-2013 09:31 AM
Project idea Mike Sign Making 5 03-10-2013 07:07 PM
Twilight project idea Mike Project Plans and How To 15 01-01-2013 12:36 AM
Tambour Desk Project Idea Wood-e Project Plans and How To 6 01-14-2011 12:34 PM
Controller Table: Route out slots for trim pieces? silentblackhat General Routing 0 07-17-2010 02:57 PM
