Workbench Tenon Length? - Router Forums
 8Likes
  • 4 Post By Cherryville Chuck
  • 2 Post By DesertRatTom
  • 1 Post By jemangin
  • 1 Post By Ray Newman
post #1 of 9 (permalink) Old 05-14-2017, 02:12 PM Thread Starter
Gaia's Avatar
First Name: Peter
Default Workbench Tenon Length?
See attached photo.
I'm making a woodworkers workbench, my first. The bench is based on this Instructables design. Building a Real Woodworker's Workbench: 32 Steps (with Pictures)
Instead of mortise and tenon joinery he uses threaded rod with nuts on the ends to pull the whole base, frame together. I intend to use mortise and tenon joinery instead. In his design he has the stretchers positioned in the middle of the legs.
The legs will be 100 x 100 PAR and the long and short stretchers will be 50 x 100 PAR. I'm not going to be able to use the rule of 3rds for the length of the tenons. So how long and also how thick should I make the tenons, to insure maximum structural integrity of the workbench?
I'll be using 100 x 100 " green split centre free " sawn Redwood, unsorted is the best grade. Green doesn't mean the Redwood hasn't been air or kiln dried.
Cheers.
Gaia is offline
post #2 of 9 (permalink) Old 05-14-2017, 05:00 PM
Peter anytime lumber is described as green it usually means that it hasn't been dried. Redwood wouldn't be my first choice for a stretcher. It's a soft wood that is normally used for outdoor applications because of its weather resistance. It can also resist glue adhesion because of its natural oiliness. IMO pine or D. Fir would be better and maybe cheaper. Redwood tends to command a good price here.
I used the bolt and cross dowel for my own workbench and it has worked perfectly for around 25 years. It's much simpler and offers the option to tighten it later if needed. A glued tenon joint doesn't give and racking forces can break them loose, something you wouldn't have to worry about with the cross dowel and bolt. Joints that get stressed are often better with mechanical fasteners.
Gaia, jj777746, MYB506 and 1 others like this.
post #3 of 9 (permalink) Old 05-15-2017, 09:53 AM
I agree that redwood is way to soft for this use. The racking force of, say, hand planing might not affect the glue, but could very easily tear the soft wood apart at the joint. I would at least use Douglas Fir but better yet, some harder wood. Many high grade work benches use Maple. Having both an end and a front mounted vise is a really good idea.
The thickness of the top increases the hold of dog hole clamps and increases the mass so the table stays put. That design should last you 150 years or so.
Gaia and ggom like this.
post #4 of 9 (permalink) Old 05-15-2017, 01:41 PM
First Name: Jamie
These are the bench bolts(Lee Valley)Veritas® Special Bench Bolts - Lee Valley Tools recommended by Chris Schwarz in his simpler bench designs.
For my bench refurbish I used through tenons made of Douglas fir and double wedged them so I could tighten it when it gets loose and break it down if necessary.
Gaia likes this.
jemangin is offline
post #5 of 9 (permalink) Old 05-15-2017, 02:47 PM
First Name: Ray
As the poster is in the UK, wonder if he is referring to "European Redwood" -- Pinus Sylvestris -- a member of the pine family? Seems it is also called "Scots Pine."
European Redwood | Bryceland Timber ? Total Timber Solutions ? Timber, Flooring, Doors
https://en.wikipedia.org/wiki/Scots_pine
Gaia likes this.
Ray Newman is offline
post #6 of 9 (permalink) Old 05-16-2017, 09:18 AM Thread Starter
Gaia's Avatar
First Name: Peter
The description green split center free might just be the English way of describing and in fact timber is properly kiln/air dried. I'll check and let you know. I have a 40mm Beech work top, in Europe Beech is quite a popular choice for commercial bench makers as relatively cheap and available. I'm thinking of going for Beech rather than the Redwood. I've also decided to use the original design of using threaded rod and nuts to hold frame together. I only started to think about M/T as other people said too. Starts to differ from the plan and starts getting..... complicated.Tendon going into the legs in the design I mention, won't be the 2/3 long and consequently I don't think they would be as robust as needs be.
Gaia is offline
post #7 of 9 (permalink) Old 05-16-2017, 09:21 AM Thread Starter
Gaia's Avatar
First Name: Peter
I know Maple is a very popular choice for benches in the States for the same reasons that Beech is used in Europe, UK.
Thanks for your reply.
Gaia is offline
post #8 of 9 (permalink) Old 05-16-2017, 09:23 AM Thread Starter
Gaia's Avatar
First Name: Peter
OK thanks.
Gaia is offline
post #9 of 9 (permalink) Old 05-16-2017, 09:24 AM Thread Starter
Gaia's Avatar
First Name: Peter
Yes, Pinus Sylvestris
Gaia is offline
Tenon Length Seldonman Project Plans and How To 4 11-09-2016 11:16 AM
Trimming Tenon To Fit Mortise. Gaia Tools and Woodworking 16 07-22-2015 05:57 PM
Shank Length vs. Cutting Length (or carbide height) in Straight Bits xzJoel Router Bits - Types and Usage 4 05-12-2012 10:11 PM
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 09:42 PM
mortise & tenon jig yairfe Jigs and Fixtures 23 10-21-2009 05:49 PM
