Tongue & groove? - Router Forums
 6Likes
post #1 of 24 (permalink) Old 06-05-2017, 12:20 PM Thread Starter
First Name: Quenten
Default Tongue & groove?
A customer wants to use some of my lumber to decorate one of the walls in her house. She likes the look of the rough finish that the band sawmill leaves when I'm cutting. She wants T&G 1X6's. That's going to be quite a few boards and a lot of routing. Is there a better/faster way to cut all these T&G's?
I was thinking I could dado tongues if I used enough shims in the middle between, the dado blades, then dado the grooves by shimming on each side of the cutter(s). Anybody tried this, or is there a better way?
Tonto1 is offline
post #2 of 24 (permalink) Old 06-05-2017, 12:43 PM
Gene Howe's Avatar
First Name: Gene
On a router table, I'd guess. One set up per tongue or groove. The way you described means a lot of finicky fiddlin', it seems.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #3 of 24 (permalink) Old 06-05-2017, 01:30 PM Thread Starter
First Name: Quenten
I was afraid of that, looks like I'm just in for a lot of routing! Good thing I enjoy woodworking. The boards are Slash Pine. How many passes do you estimate it will take for each edge? This will be my first time routing T&G's.
Tonto1 is offline
post #4 of 24 (permalink) Old 06-05-2017, 03:58 PM
That depends on the bits you use they sell T&G bit sets so you can do it in 2 set ups, one pass each. .
Or you could use a slotting cutter, just have 1 bit and 3 passes.
Which ever you do make a full 4 feather board set up. Two before the cut, top/side, and two after the cut. there is nothing more frustrating than finding the slot or tongue too shallow in the middle when trying to install. Also cut a good amount extra ,it will save having to try to match your original set up again if you run a board or two short. VOE.
https://www.amazon.com/Freud-Adjusta.../dp/B00006XMTT
https://www.amazon.com/MLCS-Stackabl...SIN=B000VJKW26
https://www.amazon.com/CMT-822-316-1...SIN=B001NIA3QO
Herb Stoops is offline
post #5 of 24 (permalink) Old 06-05-2017, 04:34 PM
Contributor of the Month
I'm assuming that she likes the look of the bevels between the board edges? How are you planning on making the bevels?
Instead of a tongue and groove router bit set how about cutting grooves on both sides of the boards with a router slot cutter or table saw dado blade (I just saw that Infinity has a new saw blade that cuts a 1/4" groove) and then using splines/slip tongues to join the boards. You could also join them with biscuits....no tongue or groove cutting.....just have to do the bevels.
JIMMIEM is offline
post #6 of 24 (permalink) Old 06-05-2017, 05:18 PM Thread Starter
First Name: Quenten
She didn't say anything about bevels. She has some pictures of some finished walls. It seems it's getting popular to redo walls with used pallet boards (no bevels). They just tear the pallets apart & nail the boards onto the wall. Some are artistic with complicated patters. It's too much work for her to break them down, so she asked if I could mill her the boards and she would stain them to look more rustic. I was worried about them warping over time, so I asked if she wanted me to T&G them. I know the v-groove looks nice as well as hiding imperfections...don't think she cares one way or another. A little variation should add to the rustic look! Just sounds like a lot of routing (which it is, but then, the price goes up as more labor is involved). I just wanted to make sure there was an easier way. And the routing might go faster than I am thinking.
Tonto1 is offline
post #7 of 24 (permalink) Old 06-05-2017, 05:39 PM
splines instead of T&G,,,
use plywood for the spline and work from the backside....
faster, less waste, less mess
jj777746 and ggom like this.
post #8 of 24 (permalink) Old 06-05-2017, 08:36 PM
First Name: Earl
I'm in the spline camp as well, or board & batten. One problem with T & G will be the inconsistent thickness of the rough sawn lumber--splines will be much more gracious with that, as would board & batten. Another positive is that it would save the step of straight-lining every piece before starting the T & G process. Stick's thought to use plywood would add strength in the joint since the layers are alternated.
Just my $0.02 worth.
earl
greenacres2 is offline
post #9 of 24 (permalink) Old 06-05-2017, 08:49 PM
I'm with Stick on using splines. Much easier to do. Cut the grooves with the good face down, it will make it easier to flatten the top.
ggom likes this.
post #10 of 24 (permalink) Old 06-05-2017, 08:55 PM
Using a table saw would be faster than using router. Probably need more than 1 pass with a router. Another option to plywood splines is getting a piece of 1/4" hardwood and ripping splines on the table saw. To make the spline fit easier, set up the router table with a 1/8" roundover bit and round over all 4 edges of the spline....this will make them easier to insert into the grooves in the edges of the boards.
JIMMIEM is offline
Tongue and Groove width nrudnick Router Bits - Types and Usage 12 05-22-2017 07:00 AM
Tongue and groove tearout Mrs C Portable Routing 26 07-26-2016 12:32 AM
Groove and Tennon Joint Construction neville9999 General Routing 3 11-19-2013 10:15 AM
Spline vs. Tongue & groove wanart General Routing 1 02-28-2006 06:22 AM
Tongue and groove bits archer_456 General Routing 4 02-18-2005 05:51 AM
