How I made my canes. - Router Forums
 32Likes
post #1 of 23 (permalink) Old 06-09-2017, 01:05 AM Thread Starter
JOAT's Avatar
First Name: Theo
Default How I made my canes.
Hmm, at least two of the photos are NOT in the order I posted them. Not a clue how or why that happened.
OK, I am still making canes, for myself, and to sell (at least will be once I can get back into the shop - long story, and I likely won't tell it). Right now, among other things, am having to redesign every cane handle I had, because the latest version, is made totally differently, yet somewhat the same. After my Gen 5 canes I started making changes in how the canes are made, and think I am now on Gen 8. I won't go into making my Gen 8 canes, but this is to show how I made my Gen 3, 4, & 5, canes.
Gen 1 canes. Started out making canes from some nice saplings that had been air drying in my shop for 10+ years. Got a lot of good comments on them, sold a few, gave a few away, lost a few by putting them on top of my vehicle while engaged in other things and drove off with them still on the roof. This went on for a while, then slipped on an icy step, landed on my sapling cane, and snapped it like a twig, and didn't even know it until I got up. That is when I went to plywood canes.
Gen 2 canes. Made a cane master I liked, traced around it, rough cut, routed out 1/2 of a cane, from 1/2" plywood. Traced around that, rough cut, glued it down, routed around it, and viola, had a nice light, and strong, cane. Made a few of those, then did some mods.
First photo. Gen 3 cane. Pretty sure I got inspiration for this from looking at Aztec and Mayan hieroglyphics, because I can't figure out where else that design would have come from. The lozenge was added because I found out some people liked to put pictures, or write, on their canes, so decided to give them some space. You can't see it, but on the lozenge it says 'test cane'. That is because I painted it (has no finish) to see how it held up, and the shaft is a bit rough, just proof of concept. The side showing has held up well. The other side I painted on the glued on paper pattern, and a lot of the paint where it is gripped has worn or flaked off. Right now I am using it daily. I am pretty sure if I had used magic markers it would have held up a whole lot better.
The next three photos are some of my Gen 3, 4, & 5, cane handle designs. They are all made the same way, just changes to the shaft/lozenge design.
The next two photos are how the Gen 3, 4, & 5, canes were made. The first is the masters laid out on a rough cut cane. The second is the first half of a cane routed out. I have said before I nail my masters, now here is proof. You can see the nail holes in the routed cane half, but that will be glued nail holes down to another rough cut piece, then routed, and viola, a cane. I drill a lot of nail pilot holes, more than really needed, but I really like the option of more nails just in case some of them start getting loose. If they do, I either add more nails, or whack them down all the way.
The next three photos are of finished Gen 3, 4, & 5, canes. The designs are fine tip magic marker, and the finish is about five coats of 50/50 or less thinned Titebond II glue. The glue finish has held up well for several years, and I will likely keep using it - no smell, dries enough to handle and apply another coat in minutes, inexpensive, and water cleanup.
For the Gen 6 canes, I made changes to how the canes are made, so instead of three masters to make a one piece cane, I came up with four masters, with the cane a total of five pieces; however, was then able to cut the number of masters to three. Gen 7 & 8, more changes to the lozenge mainly. None of these have been made, but will proceed with Gen 8.
With all of my previous cane handles I sketched each design out individually. This gave some nice designs, but was time consuming. So decided to trace the painted cane in the first photo, and use that handle shape because it is very comfortable, and will provide uniformity. Will keep the basic handle and shaft shapes, but expand from there.
The next photo is the cane tracing.
The photo after that is what I will actually base my master on.
And the photo after that one is how I will do some of my designs - trace the handle master, then trace a circle.
The next photo shows a basic blank handle design. I'll nail my master, rout around the handle and shaft, not touching the circle, for that I will close cut with my scrollsaw and then sand to final shape. That will give the first half of that particular master, and then can draw different designs on the same shape.
And a very simple design.
The next three photos are examples of some of my designs. The last one was intended to be a dog, but looks more like a rat.
The next photo is two examples of designs without using the circle part. The top one is either Groucho Marx or the devil. And the bottom not sure where that one came from.
Next photo is part way thru my buzzard series. I started the same as the other designs, but the handle is changed from the others.
And last photo is my revamp of the cane in the first photo. Below that is a two headed cane design.
Still have a load of designs I need to update, including my vampire ducks, a rabbit or two, an elephant, a lion, frog, and I don't know what all else.
I started making canes because I use one, and didn't like the store bought ones. Discovered I like to make them, so will keep a few for myself, and see if I can start selling some as a steady business. Plan on making some Wounded Warrior canes, but haven't come up with a design I really like yet. Also looking for a few designs for little kids - I know some have to use a cane for whatever reason, so figure they'd like a more fun cane than just a blah cane, just need to figure out what designs a little kid would like for a cane - think maybe one or two of my rabbets, one of the elephants, maybe one or two others - suggestions for handles for these would be welcome. All my canes will be for sale, except for the Wounded Warrior, and kids' canes.
Well, I think I explained my cane making methods so anyone here can make one.
kp91, Gene Howe, TenGees and 8 others like this.
JOAT is offline
post #2 of 23 (permalink) Old 06-09-2017, 06:33 AM
Glad you put up some pictures Theo, those are some very original designs. Creative, fun and real conversation starters. Never thought about making a cane that wasn't round. I suppose you could glue up a couple of layers of half inch BB, make the shaft an inch wide, then use a half inch roundover bit to make it round. I guess I'm thinking inside a box, so to speak.
pinehunter likes this.
post #3 of 23 (permalink) Old 06-09-2017, 06:56 AM Thread Starter
JOAT's Avatar
First Name: Theo
My canes are just a tad different, but every thing is different for a reason. They are two layers of 1/2" plywood, so they are completely square, which I think is stronger than a round cane, and it will not roll off a table or counter being square. I hit the corners with my ROS, rather than a router bit, much faster that way. They almost always have a hooked end, useful for hanging on a car door handle, pulling stuff off a high grocery shelf, or reaching in and pulling something out of the back of a shelf. And it's a lot of fun making different designs, some I can do in a minute or so for one of the birds say, took an hour or so making a new design of an undecorated cane I like a lot, still working out my new grumpy turtle, and it's a real laugh to take my Lowes cane to Lowes and have the cashier scan it, amazes most of the cashiers. They are actually quite light, but I figure they're sturdy enough to be able to beat an attacking dog to death if need be, the lozenge was not designed for it, but does provide some extra weight at the handle end to help in that. I figure if you're gonna have a cane might as well have one a bit different. Besides, couldn't find any I liked, so that's what started me on making them. Later I'll try my hand at walking staffs too. And the glue finish makes the plies really stand out.
kp91, MEBCWD and jj777746 like this.
JOAT is offline
post #4 of 23 (permalink) Old 06-09-2017, 08:48 AM
First Name: Richard
Like the canes, Theo. Like that they are different and unusual. I think those of us that use canes are very cognizant of what others are using. I know I always look for different ones. I've only made a couple and liked one and scrapped the other before wasting finish on it.
CabinCreek likes this.
Shop guy is offline
post #5 of 23 (permalink) Old 06-09-2017, 08:56 AM
jj777746's Avatar
Very original Theo.Could you show a picture of Grumpy Turtle when it's finalised ? I had an idea how you might change his shell but it wouldn't leave room for a full hand grip.Good luck with them all,Jamesjj.
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is offline
post #6 of 23 (permalink) Old 06-09-2017, 09:56 AM
Gee Theo,
A CNC machine and some 2x4' pieces of plywood of your choice - you would be buying paint and stain by the gallon to finish em all. Tom would give you a marketing plan, and you're off to the races!!
Good original designs!!
MEBCWD and Gaffboat like this.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is online now
post #7 of 23 (permalink) Old 06-09-2017, 10:06 AM
rrrun's Avatar
First Name: Henry
These are fun ... and life should be fun. Great job!
Love the pictures.
I suspect finding events to sell these will be difficult ... most craft fairs & boutiques involve a lot of walking, which could be a problem for your final users. On the other hand, you need to get people to see these, and having them visible at events may get family members/friends to get cane seekers to find you. If you're not out there, how could anyone find you?
Best of luck.
kp91 likes this.
Henry
Santa Clarita, CA
www.MowryJournal.com
rrrun is offline
post #8 of 23 (permalink) Old 06-09-2017, 12:51 PM
MEBCWD's Avatar
Theo I like the fun designs and I'm sure you are having fun creating each and everyone.
You can tell John is a CNC'er because, like most of us with CNC machines, he can see these designs being drawn up in the software and cutting rights and lefts and gluing the 2 sides together several at a time.
Let me see ..... if you glue two pieces of plywood together and use 2 sided carving then all that would be let to do after cutting would be a little cleanup and finish.
Of course you would miss all the fun you are having making each one with it's own personality.
MEBCWD is offline
post #9 of 23 (permalink) Old 06-09-2017, 01:57 PM
hawkeye10's Avatar
First Name: Don
Very nice canes Theo. I really like them. If you don't mind I would like to copy one of them. Here is the one and only cane I made and it's not round as I don't have a lathe. I used a round over bit. It's cherry and I had to glue two pieces together. Thanks for posting this Theo.
kp91 and Gaffboat like this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #10 of 23 (permalink) Old 06-09-2017, 02:33 PM
kp91's Avatar
First Name: Doug
Theo,
Hope you are back in the shop soon so you can share some more great designs.
I have only made one cane, and I am now aware of how peculiar users are about what they expect in size, weight, handle shape, etc.
I asked a lot of people who use them at church what makes a good cane, and I still had to adjust it after my father started using it.
Thanks for the great tutorial, I may have to make a more whimsical one. Who knows, maybe one of the dolphins from the submarine insignia as the handle.
History of U.S. Submarine Warfare Insignia - "DOLPHINS"
1 John 1:9
Fredericksburg, VA
kp91 is online now
Show me your home made router table Jack Wilson Show N' Tell 10 01-19-2015 02:52 AM
I'm making some canes JOAT Project Plans and How To 26 11-07-2012 06:54 PM
Shop made Dovetail Jig PaulDaniels Jigs and Fixtures 4 06-25-2012 06:45 AM
Shop made router table and lift Chris Curl Table-mounted Routing 0 04-02-2012 01:15 AM
overcomming home made router table snags matey Table-mounted Routing 5 01-27-2011 08:36 PM
