Donation Boxes - Router Forums
 21Likes
post #1 of 19 (permalink) Old 08-22-2017, 09:48 AM Thread Starter
RDSpears's Avatar
First Name: Raymond
Default Donation Boxes
Been charged with making Donation/Suggestion boxes for church. Anyone here ever make one of these from oak? All suggestions on size, designs welcomed. My initial plan is to make portable on stand so the box or boxes can be move from one location to another if needed. Thanks in advance for you comments.
RDSpears is offline
post #2 of 19 (permalink) Old 08-22-2017, 10:29 AM
Hi, I think I'd want a pretty strong box, which means box or dovetail joints, particularly for the donation boxes.
Donation Boxes: These would depend on where they are located and whether those locations are open. Some churches keep their sanctuaries open, unattended, which leaves the donation boxes vulnerable to breakins and even theft. So these probably need to be bolted down. One alternative would be to build a box with a built in stand.
The drop slot in the box would drop the contribution through what looks like the box, down into the base. The front or rear of the base would be heavily weighted, but would have a concealed and locked door for access. I would make the stand narrower than the box to give the illusion it is merely a stand.
The top box whould likely have a slanted lid with a visible lock on it, even a padlock. That would give the impression that the upper box had all the goodies when in fact, the bulk of the contributions would remain out of sight in the base.
I guess that suggests a little cinicism about humanity, but I confess to that flaw.
The suggestion box just needs a wide slot on the top, and I would suggest some kind of slots on the side or underneath, to hold paper and pencils for the suggestions. I would put a lock on it, mainly to communicate that it is private and anonymous. I'd put a small padlock there so when the key gets lost, you can easily cut it off. It will get lost.
Just my thoughts. I think oak is a good choice, white if you can get it. Scrape, don't sand. Finish appropriate to the rest of the furnishings, the pews in particular. You could use ply for the panels. These are likely to be there for a couple of generations, so build solid.
DesertRatTom is online now
post #3 of 19 (permalink) Old 08-22-2017, 11:32 AM
kp91's Avatar
First Name: Doug
http://www.routerforums.com/kp91s-ga...-cash-box.html
Scrap walnut and oak fence boards.... this thing has survived 4 years of being carried back and forth to Girl Scouts. The link above has better pictures
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #4 of 19 (permalink) Old 08-22-2017, 11:52 AM
Gaffboat's Avatar
First Name: Oliver
I like Tom's ideas. They should be pretty easy to incorporate into any number of visual styles for the boxes. I especially like the idea of the donations dropping down into what appears to be the stand.
MEBCWD likes this.
Gaffboat is offline
post #5 of 19 (permalink) Old 08-22-2017, 12:37 PM
vindaloo's Avatar
First Name: Angie
Originally Posted by DesertRatTom View Post
.................I guess that suggests a little cinicism about humanity, but I confess to that flaw..............
Not cinicism, merely reality, there are scum out there who would do such a thing.
MEBCWD likes this.
When everything around you is going to pot, get out in the workshop.
vindaloo is offline
post #6 of 19 (permalink) Old 08-22-2017, 01:18 PM
JOAT's Avatar
First Name: Theo
Pretty much agree with Tom. But I would also make it heavy enough that it would take at least two pretty strong men to move it.
DesertRatTom likes this.
JOAT is online now
post #7 of 19 (permalink) Old 08-22-2017, 02:45 PM
If the box is going to be passed around, a pretty conventional box with a nice sized slot big enough for bills and a donation envelope would do nicely, in that case a lighter construction would be better, perhaps as light as 1/4 to 1/2 inch material. Many times churches use contribution envelopes so they can send tax receipts to contributors. If that's a possibility, then the box has to be deep enough to hold the envelopes.
post #8 of 19 (permalink) Old 08-23-2017, 06:49 AM
kywoodchopper's Avatar
First Name: malcolm
Default Boxes
Several years ago I made a box for a church to put pray request in. This one is made of cherry with a spalted maple top. I believe it was about 4" H * 10" * 12". Malcolm / Kentucky USA
kp91, vindaloo, chessnut2 and 8 others like this.
kywoodchopper is offline
post #9 of 19 (permalink) Old 08-23-2017, 10:03 AM
TenGees's Avatar
First Name: Paul
Very nice, Malcolm. Those should be inspiration for Raymond.
Gaffboat likes this.
TenGees is offline
post #10 of 19 (permalink) Old 08-23-2017, 11:08 AM
Knothead47's Avatar
Our church now had kiosks in a couple of places where you can put your offering on credit card.
As for humanity......my father always said there are people who would steal Christ off the cross and then go back after dark for the nails.
John T.
Knothead47 is offline
Flintstone Boxes Herb Stoops Show N' Tell 13 09-01-2019 01:42 PM
Wooden basket and boxes kywoodchopper Member Galleries 20 12-18-2017 11:07 PM
Boxes from the Man Cave kywoodchopper General Routing 15 06-14-2016 06:28 AM
Boxes/ Bandsaw Boxes good Christmas presents Herb Stoops Show N' Tell 12 12-21-2014 06:16 AM
Boxes, Trivets and Stools xplorx4 Show N' Tell 5 10-26-2011 03:49 AM
