Mission Style Furniture Questions - Router Forums
 15Likes
post #1 of 18 (permalink) Old 09-30-2017, 06:55 AM Thread Starter
Contributor of the Month
Default Mission Style Furniture Questions
I am planning on building a couch tray table. The couch's end tables are Mission Style. I have read several articles on Mission Style and have a good of the elements. What I haven't found any info on is 'proportions'. I understand the Golden Ratio concept but that doesn't provide any help here. The end table tops are almost twice as large as the couch table so I'm specifically wondering about sizing the couch table's leg thickness, aprons, and, slats so they are proportional.
Would appreciate any help. Thank You.
JIMMIEM is offline
post #2 of 18 (permalink) Old 09-30-2017, 08:29 AM
This site semed to have a little history and links at the bottom of the page to other sites Mission Style Furniture
What I notice is that legs in mission style always seem to be 2x2, oak, finished dark. I also see a lot of flat panels, or panels filled in with carefully spaced 1/2 x 1 pieces. I guess Mission style is pretty closely related to Craftsman, which incorporates tapered legs and parts. Mission panels are set stiles and rails that are square all round, whereas Craftsman have a slight angle on the inside edge of the panel's frame.
I learned that there are two "golden means", one is a one third two thirds, the other is more modern, 3 fifths, two fifths. Pick the one you prefer and proportion the pieces by that ratio for Craftsman style. Mission is still proportional in that sense, but it is straifht up and down, without tapers--very simple. Both styles use mortise and tennon joints, strong, simple.
I did a lot of design work in my past lives, and those ratios cut across all disciplines.
rrrun likes this.
post #3 of 18 (permalink) Old 09-30-2017, 03:50 PM
Mission style furniture was a part of the Arts and Crafts era. The idea was to be able to go to a lumberyard and buy the material readily sized for what you needed. However, according to the parts lists included with some of the designs it is apparent that lumberyards would do more then than they will now. If you we search H. H. Windsor you may find free downloads of his 3 books. I have a paperback copy and they are usually cheap because the copyrights expired decades ago.
The dark color Tom mentioned was usually from fuming the oak with ammonia.
JIMMIEM and TenGees like this.
post #4 of 18 (permalink) Old 10-01-2017, 07:59 AM
TwoSkies57's Avatar
Jim..
A pencil, grid paper and a tape measure is all you need here. Use what you got to base the design of what you want. Mission design is more about right angles, flat work and quality craftsmanship.
Ray Newman and CharlesWebster like this.
Skipper the Penguin
TwoSkies57 is offline
post #5 of 18 (permalink) Old 10-01-2017, 08:51 AM
hawkeye10's Avatar
First Name: Don
I like the looks of Mission and Shaker furniture.
TwoSkies57 and CharlesWebster like this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #6 of 18 (permalink) Old 10-01-2017, 08:57 AM
TwoSkies57's Avatar
Thumbs up
I agree.. in the right setting extremely attractive.
Skipper the Penguin
post #7 of 18 (permalink) Old 10-02-2017, 07:36 AM Thread Starter
I just found some H.H. Windsor books online. I'll swing by the library or bookstore and check them out. Thank You.
JIMMIEM is offline
post #8 of 18 (permalink) Old 11-26-2017, 07:11 AM Thread Starter
The end tables have tops that are 23" X 28" and square legs that are 2 1/4" X 2 1/4". The couch tray table that I am building will have a top 14 3/4" X 24". The legs will be square but I'm wondering if they should be scaled down a bit to maybe 2" X 2" or 1 3/4" X 1 3/4". What do you folks think?
JIMMIEM is offline
post #9 of 18 (permalink) Old 11-26-2017, 07:53 AM
TwoSkies57's Avatar
Just my opinion, but I'd scale em down to 1 3/4..
JIMMIEM likes this.
Skipper the Penguin
post #10 of 18 (permalink) Old 11-26-2017, 08:54 AM Thread Starter
I located the free downloads of the 3 H.H. Windsor books. They can be downloaded in several different formats or you can just read them on-line.
Thank You for telling me about the books.
Cherryville Chuck likes this.
JIMMIEM is offline
Oak-Park style table questions - Pt. 2 - features? username1 Table-mounted Routing 15 07-30-2017 09:43 AM
Oak-Park style table questions username1 General Routing 34 07-17-2017 07:21 PM
Free Mission Furniture plans Cherryville Chuck Tools and Woodworking 10 05-24-2013 12:18 PM
Greene and Greene style furniture Laramie New Member Introductions 5 06-18-2012 11:40 AM
Bit for Mission style panel doors? D.C. Router Bits - Types and Usage 4 01-02-2012 06:57 AM
