Attach legs to table base - Router Forums
 6Likes
  • 1 Post By JIMMIEM
  • 3 Post By mimac
  • 2 Post By Cherryville Chuck
post #1 of 5 (permalink) Old 12-03-2017, 07:52 PM Thread Starter
Contributor of the Month
Default Attach legs to table base
I'm making a Red Oak sofa server similar to the attached picture. My top will be 24" X 14 3/4" X 3/4" made up of edged glued boards. Top will be attached to the skirt boards with table top clips. The legs will be 1 3/4" X 1 3/4". I am planning on attaching the legs to the base with screws driven up through the bottom of the base. The screw heads will be recessed and the screw holes elongated to allow for wood movement. Any other methods to attach the legs to the base?
Danman1957 likes this.
JIMMIEM is offline
post #2 of 5 (permalink) Old 12-03-2017, 09:14 PM
mimac's Avatar
First Name: Brian
Sliding dovetails
Danman1957, Stick486 and ggom like this.
mimac is offline
post #3 of 5 (permalink) Old 12-04-2017, 02:44 AM
Whenever I pin something down that has to allow for movement I make one of the holes with no allowance for movement. In this case I would make the back attachment solid and the ones going forward to allow movement. This keeps the back edge flush. If I were pinning a breadboard end on a table I would make the center attachment solid and let the rest move from the center going outward either way. That way if the end was shorter or longer because of seasonal movement at least it would be equal on both sides instead of possibly being all on one side.
Danman1957 and Stick486 like this.
post #4 of 5 (permalink) Old 12-04-2017, 07:05 AM Thread Starter
Should I just make the top and base from cabinet grade red oak plywood and edge them with solid wood to eliminate potential movement? Note: I installed solid hardwood floors throughout the house a few years ago and monitor/maintain recommended humidity levels year round via central a/c (summer) and whole house humidifier (winter).
JIMMIEM is offline
post #5 of 5 (permalink) Old 12-04-2017, 10:18 AM
You could Jim but plywood doesn't have the same look as solid wood as a rule. There's nothing wrong with that design you just have to allow certain parts to move. The area where you will need to allow movement are:
-The bottom and top rails that the slats attach to. They are cross grain with the top and bottom. Z clips work well for those.
-The braces that hold the legs upright. The bottom edge of those is cross grain and they will be attached to long grain so over time that may cause them to split. I think I would pin the cross rail down with elongated holes and then only attach the "toes" of the braces to the bottom panel. Those braces are mostly there to resist the tipping force of the top.
Everything else is long grain lined up with long grain so there won't be problems with those.
Fold down router table Gaffboat Table-mounted Routing 21 09-09-2018 06:41 PM
New fence (Part 2) Out Feed Table Coleve Show N' Tell 23 11-16-2017 12:09 PM
Making sawhorses, the easy way JOAT Project Plans and How To 15 07-07-2016 05:08 AM
Yet another router table build ... JohnBFisher Table-mounted Routing 23 11-13-2014 11:33 AM
Question About Table Legs? Jerry Bowen Lobby 12 03-03-2014 11:28 AM
