Table Saw MDF Alignment Plate - Router Forums
 4Likes
  • 1 Post By Gene Howe
  • 1 Post By JIMMIEM
  • 1 Post By Cherryville Chuck
  • 1 Post By JIMMIEM
post #1 of 8 (permalink) Old 12-13-2017, 04:39 PM Thread Starter
Contributor of the Month
Default Table Saw MDF Alignment Plate
I'm checking my table saw blade alignment. Instead of doing the alignment with a saw blade I am thinking that a piece of 1/2" MDF might make a good alignment plate....should be dead flat. Your thoughts?
JIMMIEM is offline
post #2 of 8 (permalink) Old 12-13-2017, 04:57 PM
jj777746's Avatar
Hi Jim, seems to me that once you start tightening your arbor nuts,it's gonna throw your mdf "blade" out of alignment.Do you have room for blade stiffeners? May help keep it straight. Let us know how it goes eh Jim?
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is online now
post #3 of 8 (permalink) Old 12-13-2017, 04:59 PM
Gene Howe's Avatar
First Name: Gene
Just don't tighten it too tight. If you have room, you might put a circular saw blade on before the nut as a stiffener.
jj777746 likes this.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #4 of 8 (permalink) Old 12-13-2017, 05:39 PM Thread Starter
There is room for blade stiffeners. Not enough room for saw blade(s). It's a contractor saw and I have PALS to help with the alignment and I have a plunger dial indicator and I've been able to get it very accurate in the past.
I usually install a premium blade for accuracy....should be interesting how the MDF will work out.
I'll let you know.
JIMMIEM is offline
post #5 of 8 (permalink) Old 12-14-2017, 10:42 AM
MEBCWD's Avatar
Jim if you use the MDF plate you still want to mark the point that the measurement is taken form and use the same point front and back just like you should when using a saw blade you should use the same tooth front and back. Using the same point or tooth minimizes discrepancies from bent blades or warped plates.
MEBCWD is offline
post #6 of 8 (permalink) Old 12-14-2017, 10:55 AM
Bob Adams's Avatar
First Name: Bob
Years ago I bought a master plate to for table to blade alignment. Works really well eliminates any variance between blades. I thought I was really smart, until now... mdf is a great idea, wish I had thought of it and saved my $60.00.
Bob Adams is offline
post #7 of 8 (permalink) Old 12-14-2017, 12:31 PM
I've heard of guys using the sanding plate for table saws too. When you try the mdf set up the indicator and rotate the disc and see if you get different readings. If not it's good to go.
Ray Newman likes this.
post #8 of 8 (permalink) Old 12-16-2017, 02:41 PM Thread Starter
The MDF (1/2") alignment plate worked well. Very easy to put a dot with a fine tip felt pen/sharpie and set the plunge indicator tip on it and then rotate the plate and hit the dot again.
JIMMIEM is offline
Newbie installs a mounting plate using one bit... matt1710 Table-mounted Routing 11 01-03-2013 02:34 AM
Anyone have the smaller Router Insert Plate Rockler use to make. amassey08873 Table-mounted Routing 9 07-12-2012 01:15 AM
Craftex Sliding Table Saw Attachment CX200S CanuckGal Tool Reviews 6 07-02-2012 10:19 AM
Do I need a router plate for my new table? Ryan's Dad Table-mounted Routing 16 09-16-2011 06:53 PM
