Mike so happens woodsmith has a combo router build set of plans - Router Forums
 8Likes
post #1 of 15 (permalink) Old 12-25-2017, 06:56 PM Thread Starter
roofner's Avatar
First Name: Gary
Default Mike so happens woodsmith has a combo router build set of plans
Here is another nice project build from woodsmith latest tv series build now showing in my area.
https://www.woodsmithplans.com/plan/...-router-table/
chessnut2 and ksidwy like this.
roofner is offline
post #2 of 15 (permalink) Old 12-25-2017, 11:47 PM
That's a good design Gary. Basically you use the tall fence for a table when it's rotated. Years ago I made a horizontal table and they can be very useful since you can rout over the top of your piece as well as below so that offers possibilities that only routing below doesn't
There is one VERY important thing to remember if you are routing with a horizontal table and that is that feed direction is reversed when the bit is below the work and should be left to right. If the bit is above the work then you go back to the standard right to left.
post #3 of 15 (permalink) Old 12-26-2017, 06:02 PM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
It is an interesting idea but the more I looked at it then I cant see why the table gets flipped up, a first glance you could think it was a variable angle arbour buts it's not as regardless of the angle the table is sitting on then cutter is still square to the table and the fence so regardless of how you set it the cutter angle is still the same, Mike is right and the feed direction would get reversed still I will think about this some more and see if I can see why anyone would need to flip a router table 90degs and use the fence as the table instead of use the table itself. It's a lot of work to make the table so it could flip and so far I don't see why I would do that. N
neville9999 is offline
post #4 of 15 (permalink) Old 12-26-2017, 11:30 PM
N I used it to make some picture frames. The wife had picked some out at a frame shop that she liked but they were $25 per running foot. I realized they were just a collection of simple curves with a bead at the top. The problem was that it would have been very difficult to rout those unless the profiled part was up and the back was on the table.
I think an overhead router would have worked too and I've been keeping my eyes open for an old radial drill press, thinking it might be easy to convert but I haven't run across one yet.
post #5 of 15 (permalink) Old 12-26-2017, 11:55 PM
JOAT's Avatar
First Name: Theo
This help? Homemade Pin Router - HomemadeTools.net
JOAT is offline
post #6 of 15 (permalink) Old 12-27-2017, 02:26 AM
Not exactly Theo but if you click on the image of it it takes you to the mandolin cafe site and the post above it there is interesting. BJ had made an overhead router setup by adding an L bracket onto the end of a radial arm saw motor and he said it worked pretty good. I'd like something easy to raise and lower. That's why I thought a radial drill press.
post #7 of 15 (permalink) Old 12-27-2017, 12:12 PM
JOAT's Avatar
First Name: Theo
Ah, gotcha now. And know exactly what would work for you. And, of course, can't remember where I saw it - it has been a good while. I'll post it if I ever run across it. In the meantime, found this, don't know if it will be of use to you or not, but maybe someone. Homemade Overhead Router System - HomemadeTools.net
I don't need an overhead router, but if I did, I'm sure I could come up with something workable, different, and ugly. Hmm, just hit me, I'm thinking a router mounted to a chunk of 2X4, between 2 chunks of 2X4, backed with 2 chunks of 2X6, separated slightly making a slot, and height likely adjustable by hand but a threaded rod could be used, and locked in place with a bolt (or 2). And all glued together - I don't like metal in my shop projects especially, then if I repurpose the wood, nothing to damage my saw or planer blades. And I'd paint the whole thing bright yellow, to make it cheerful, and to brighten up the shop a bit.
JOAT is offline
post #8 of 15 (permalink) Old 12-27-2017, 01:55 PM
A little bulky but it looks workable.
post #9 of 15 (permalink) Old 12-29-2017, 12:43 PM
TenGees's Avatar
First Name: Paul
I think it would make it easier to do mortises, Neville. They show the jig and stops for that. There's also some panel bits which go the other way like that... need less power for those because of the smaller radius.
I would like to be able to angle the cutter too though. That would add a lot of versatility that I could have used for my columns that I had to make a jig for: http://www.routerforums.com/general-...ml#post1327041
TenGees is offline
post #10 of 15 (permalink) Old 12-29-2017, 01:30 PM
Mark Sternberg makes one that angles to any angle you want: https://routermillwoodworks.weebly.com/
Basically what he did was to attach the frame that holds the router to a round piece of plywood that can be rotated then locked into position. I had forgotten about it until you mentioned that Paul. He posted the prototypes on the forum maybe 5 years ago now.
TenGees likes this.
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 08:51 AM
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
