DIY Sauna - Router Forums
post #1 of 7 (permalink) Old 04-24-2018, 01:42 PM Thread Starter
Default DIY Sauna
I am building a large barrel shaped sauna for an organization that I help run. I have the general outline and blueprints figured out on how I am going to do it, however I am having some difficulty figuring out how to get some of the routing done.
I am constructing the sauna out of 2" x 6" cedar planks, of which I need to create T & G joints on 32 boards and Bead and Cove joints 50 boards. I am struggling to find bits large enough to create these grooves on the 2" side.
Can anyone help me understand why these are difficult to find? or If they are easy to find and I am not looking in the right places can someone help direct me to the appropriate place to find them?
I am also open to any advice from anyone on creating these grooves in boards this large.
jon7923 is offline
post #2 of 7 (permalink) Old 04-24-2018, 02:10 PM
hello N/A.. welcome to the forums...
and reference to what to what you are wanting would be helpful...
for the bead and cove... but you aren't saying what size abs profile..
Freud Tools - Search Results for bead
Freud Tools - Search Results for Cove And Bead
instead of T&G go w/ a splined joint...
use the real deal Baltic Birch for the splines...
http://search.freudtools.com/search?...cutter&cnt=300
post #3 of 7 (permalink) Old 04-26-2018, 03:41 PM
JOAT's Avatar
First Name: Theo
Traditional saunas are square or rectangular. I would say there is a reason for that.
JOAT is offline
post #4 of 7 (permalink) Old 04-26-2018, 05:28 PM
Knothead47's Avatar
You don't need a sauna. Just spend July-September in SE TN. Or Louisiana. Square or rectangular is what I have seen over the years.
John T.
Knothead47 is offline
post #5 of 7 (permalink) Old 04-26-2018, 09:10 PM
old55's Avatar
First Name: Ross
Welcome to the forum.
Ross,
old55 is offline
post #6 of 7 (permalink) Old 04-26-2018, 11:49 PM
Welcome to the forum....
Any barrel shaped container will require chamfer shaped edges????
Is it barrel shaped or just round?
Sydney, Australia
jw2170 is offline
post #7 of 7 (permalink) Old 04-27-2018, 12:18 PM Thread Starter
Thank you for the many kind greetings to the forum and the invitation to TN and LA. My back up is to construct a box shaped sauna, this barrel shaped sauna is simple nicer on the eyes.
The following website gives decent general outlines as to what I am trying to accomplish: I am not able to post url's so google gibbonswhistler diy outdoor sauna; the website will read similare to the following... gibbonswhistler /build-diy-outdoor-sauna-backcountry
Pictures of similar saunas can be found here: search for images by using google image search term "barrel sauna"
The Sauna is more round than barrel shaped.
Would a could a round over bit and a bullnose bit that are matching create the bead and cove joint I am hoping for?
jon7923 is offline
DIY CNC router - Original design BalloonEngineer CNC Routing 22 09-06-2019 12:01 AM
DIY pallet coffee table GLOWING Daniel80 Project Plans and How To 26 04-28-2017 08:52 AM
What makes a good sauna Tiny Lobby 9 09-21-2012 12:38 AM
