Router Forums (https://www.routerforums.com/forum.php)
-   Project Plans and How To (https://www.routerforums.com/project-plans-how/)
-   -   Fairy Tale Style Bench With Chainsaw (https://www.routerforums.com/project-plans-how/136471-fairy-tale-style-bench-chainsaw.html)
JOAT 10-30-2018 11:46 AM
A lot of you already know that I think a chainsaw is a precision cutting tool. This is a pretty good example. But, it is just not my cuppa, and don't need a bench anyway. On the other hand, it could likely be easily converted to a rocking bench, don't have a downed tree tho. However, figure some of you may want to cut down a neighbor's tree, and give it a shot. You'll likely have more chance of success if you ask your neighbor first.
https://www.instructables.com/id/Fai...m_medium=email
DaninVan 10-30-2018 11:55 AM
!...using an aluminum ladder for guiding the first cut is brilliant! Both legs are coplanar which is critical.
If the first cut is perfect the following cuts will be also.
The only issue with the ladder trick is that you need a pretty decent sized log...not going to work with the small stuff.
Powered by vBulletin® - Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
