Fairy Tale Style Bench With Chainsaw - Router Forums
 1Likes
  • 1 Post By JOAT
post #1 of 2 (permalink) Old 10-30-2018, 11:46 AM Thread Starter
JOAT's Avatar
First Name: Theo
Default Fairy Tale Style Bench With Chainsaw
A lot of you already know that I think a chainsaw is a precision cutting tool. This is a pretty good example. But, it is just not my cuppa, and don't need a bench anyway. On the other hand, it could likely be easily converted to a rocking bench, don't have a downed tree tho. However, figure some of you may want to cut down a neighbor's tree, and give it a shot. You'll likely have more chance of success if you ask your neighbor first.
https://www.instructables.com/id/Fai...m_medium=email
marecat3 likes this.
JOAT is offline
post #2 of 2 (permalink) Old 10-30-2018, 11:55 AM
!...using an aluminum ladder for guiding the first cut is brilliant! Both legs are coplanar which is critical.
If the first cut is perfect the following cuts will be also.
The only issue with the ladder trick is that you need a pretty decent sized log...not going to work with the small stuff.
DaninVan is offline
Canadian fairy tale. JOAT Lobby 41 04-25-2018 09:25 AM
Work bench pictures for Khal Tom Cherryville Chuck Show N' Tell 9 08-22-2017 03:06 PM
Bench Dog BenchTop vs. The Super Bench, Bench Top Router Table emergencyshutdown Table-mounted Routing 8 11-14-2011 01:58 AM
Bench Dog 40-016 ProLift Max Dejure Tool Reviews 1 08-04-2009 04:26 AM
