Outside wood stove shop heater - Router Forums
 1Likes
  • 1 Post By Cherryville Chuck
post #1 of 4 (permalink) Old 11-19-2018, 10:18 PM Thread Starter
JOAT's Avatar
First Name: Theo
Default Outside wood stove shop heater
I've seen something along these lines, on a smaller scale. Seems to work OK. Be a good way to get rid of sawdust and such.
https://www.instructables.com/id/Out...m_medium=email
JOAT is offline
post #2 of 4 (permalink) Old 11-20-2018, 08:13 AM
Knothead47's Avatar
This will be used inside a shop? Be careful with tossing fine sawdust into it. It can flash like gasoline. A few years ago, I tossed fine sawdust on a burn pile in the back yard. It flashed and scared the bejabbers out of me. Learned not to do that again. Growing up on a farm, I heard of the same thing causing explosions in grain mills.
John T.
Knothead47 is offline
post #3 of 4 (permalink) Old 11-20-2018, 08:53 AM
That is a terribly inefficient design Theo. Particularly the heat exchanger. 90% of the heat from the fire will be lost without heating the heat exchanger. Heat exchangers work best when there are many small pipes. You want to increase the heating surface area so about 1" pipes would be somewhere around optimal in my opinion because you need to push air through them. If you were heating water then smaller yet would be better.
What would be a much better design would be to surround the heater with a plenum chamber. Cold air in from the shop at the bottom and hot air to the shop from the top. And insulate the chamber to minimize heat lost to the outside. You could also build an insulated shed around the heater. Like John said, you'd have to watch about adding sawdust.
Danman1957 likes this.
post #4 of 4 (permalink) Old 11-20-2018, 09:07 AM
Danman1957's Avatar
The flexible pipes going into the shop and back are also very inefficient and most of the heat will be lost. I live in Quebec Canada and we have a pretty cold climate so that system would not do well. I have seen some have a wood burning furnace outside that provides heat indoors but they are way more elaborate than just using a metal drum and some flex pipe.
Don't fear your tools, pay attention and respect the tools and avoid injury.
Danman1957 is offline
Xmas - I got a Triton TRA001....now what table? mikeyo76 New Member Introductions 10 12-26-2017 04:13 PM
Another Newby Tweety New Member Introductions 13 12-18-2017 06:38 AM
Line Shaft and belt Driven Wood Shop Ray Newman Tools and Woodworking 6 01-29-2017 04:33 PM
