Floating corner shelf - Router Forums
 57Likes
post #1 of 25 (permalink) Old 01-07-2019, 06:01 PM Thread Starter
RainMan 2.0's Avatar
Default Floating corner shelf
Well this is pretty dismal and I was hesitant to post , but it’s all I got lol.
It was only a bit below freezing in my shop yesterday, and I was getting tired of knocking over my poor Snake plant , so I was eyeing up this unused corner of my living room for a shelf.
Never did a floating shelf before , and have seen many ideas for straight off the wall applications , but I wanted to do the corner .
I found one idea online that I liked as it was fairly simple , so I took the easy way out and tried it .
I’ll probably add a second one below and put a vase or something on it .
I used a 2x4 and cut it 1”x1-1/2” , as the thicker it gets the deeper the shelf will end up being . Unfortunately I had no 1/2” Baltic birch left , so I used a 3/4” scrap of Baltic Birch plywood .
Would have preferred 1/2” to keep the shelf 2” deep total, but it was Sunday and WP is closed .
After I installed the strips on the wall , I placed the plywood on the top and air nailed it . Then did the same and attached the bottom. I left the pic out where I placed a piece in the front to keep it from possibly sagging , and to keep the distance equal across the front .
I used a piece of mdf moulding for a front cap. I thought air nailing everything was kind of a strange way to do it , as you have to pry it apart as opposed to removing screws to remove it , but it seems to work .
I haven’t put putty on the holes and finished it yet, as it’s just primed . I’m still looking at it and wondering if it’s to thick looking?
It would be easy to dado out the area and make it thinner where it’s attached , which would make it a total of 2” thick as opposed to 2-1/2” thick .
Or start from scratch and just buy 1/2” Baltic birch
kp91, JFPNCM, JIMMIEM and 19 others like this.
Ok ,I never insulate
RainMan 2.0 is online now
post #2 of 25 (permalink) Old 01-07-2019, 07:23 PM
I don't think it looks to thick, Rick. Good job. Right now it looks like part of the wall. If you wanted contrast, paint it dark the same color as the furniture.,
Just saying,
RainMan 2.0 likes this.
Herb Stoops is online now
post #3 of 25 (permalink) Old 01-07-2019, 07:47 PM
Nice solution, very nice looking. White works when you put that dark vase on it. I think the thickness works too because it is appropriate for the mass and visual weight of the vase. I like it a lot Rick.
DaninVan and RainMan 2.0 like this.
DesertRatTom is online now
post #4 of 25 (permalink) Old 01-07-2019, 09:46 PM
Originally Posted by RainMan 2.0 View Post
Well this is pretty dismal and I was hesitant to post , but itís all I got lol.
Iíll probably add a second one below and put a vase or something on it .
I used a 2x4 and cut it 1Ēx1-1/2Ē , as the thicker it gets the deeper the shelf will end up being . Unfortunately I had no 1/2Ē Baltic birch left , so I used a 3/4Ē scrap of Baltic Birch plywood .
Would have preferred 1/2Ē to keep the shelf 2Ē deep total, but it was Sunday and WP is closed .
I havenít put putty on the holes and finished it yet, as itís just primed . Iím still looking at it and wondering if itís to thick looking?
It would be easy to dado out the area and make it thinner where itís attached , which would make it a total of 2Ē thick as opposed to 2-1/2Ē thick .
Or start from scratch and just buy 1/2Ē Baltic birch
Was the corner square, or did you have to cope the corner to fit?
post #5 of 25 (permalink) Old 01-07-2019, 10:12 PM
roofner's Avatar
First Name: Gary
Nice job I can't do much either no heat in my shop. I did build 3 drawers for my desk . Drawer boxes are installed in the desk . Just have to make false fronts for drawers and clear coat.
roofner is offline
post #6 of 25 (permalink) Old 01-07-2019, 10:24 PM Thread Starter
Darn near square . I shaved a few mm on my belt sander . I expected as much .
Debating to tear apart and use 1/2Ē BB. This may end up being a prototype yet .
I was thinking that if I took my time , I could air nail and glue the top after the strips are attached , then use white screws underneath for the bottom plate .
This way the bottom plate could be removed accessing the screws going into the wall again. The shelf could be removed if necessary if done that way.
Not that I can see having to remove a shelf other than Iím not pleased with the height in the future .
I kind of made a mess , as I had pencil marks higher than what I wanted . I decided to drop it a bit at the time , but I need to paint it to match the wall , so nothing major.
I originally was going to mitre the top and bottom, then mitre a front cap . This way there would be no lines to see , and I could stain it and see the wood grain.
But my living room isnít really using the wood look , more like white and black .
A dark stain may work though , but there may be to much contrast .
My coffee table is a lighter colour though , and my friend mentioned itís too light . I thought it provided a bit of character to the room,as everything is dark .
Want to build a coffee and end tables someday , and was going to go a bit darker
My terminology isnít great . I call stain that stuff where you can see the grains , but I believe you oil it for that?
Is stain considered paint?
Danman1957 likes this.
post #7 of 25 (permalink) Old 01-07-2019, 10:43 PM
MT Stringer's Avatar
Looks good to me.
MT Stringer is offline
post #8 of 25 (permalink) Old 01-08-2019, 01:51 AM
I agree with Mike, it looks good the way it is.
Stain is an oil,or water base that shows the grain , then you varnish over with shellac,Poly eurthane, or lacquer.
HErb
DaninVan likes this.
post #9 of 25 (permalink) Old 01-08-2019, 07:27 AM
TwoSkies57's Avatar
Ya done good one this one Rick... if you feel it looks to "thick" or bulky, try cutting a piece of black electrical tape. Center the tape on the face of your shelf and run it from side to side. See if that doesn't break it up for you. If you like the look, paint tape and then just paint it. Alot of way to just experiment with the look before going and redoing the whole thing...
Herb Stoops likes this.
Skipper the Penguin
TwoSkies57 is offline
post #10 of 25 (permalink) Old 01-08-2019, 08:12 AM
sreilly's Avatar
First Name: Steve
Looks like it was part of the wall and belongs there as is to me. As for the finish, well that's a personal choice but to me it looks great and very functional. What else would you have done with that corner? Simple, effective, and attractive. Checks my boxes.
DesertRatTom and Herb Stoops like this.
sreilly is online now
"Ok Google" Floating Shelf...... comp56 Show N' Tell 8 09-04-2018 11:35 AM
Drilling Shelf Pin Holes without a jig and without measuring Cherryville Chuck Project Plans and How To 14 11-23-2016 05:06 PM
Floating Corner Shelf JIMMIEM Tools and Woodworking 16 01-07-2015 07:50 AM
How to Make a Shelf learnexperience General Routing 0 11-02-2011 06:49 PM
