Looking for thin,wide boards - Router Forums
 2Likes
  • 1 Post By CharleyL
  • 1 Post By difalkner
post #1 of 8 (permalink) Old 03-25-2019, 07:45 PM Thread Starter
First Name: Mickey
Default Looking for thin,wide boards
I’m looking for walnut boards preferably. Preferably 1/8” thick, but i suppose 1/4” would do fine. I need at least 9” wide, and at least 18” long. Longer is okay.
As a last resort, i could likely use a veneer if it’s on the thicker side.
Any suggestions? I’m open to suggestions to other types of wood if it can be gotten in the size i want. It simply has to contrast nicely with cedar.
Normally i use Rockler, Bell Forest, Woodcraft, or The Wood & Shop. Can’t find this size boards on either of those.
Sent from my iPhone using Tapatalk
Mickeyfolse is offline
post #2 of 8 (permalink) Old 03-25-2019, 08:17 PM
CharleyL's Avatar
First Name: Charley
You should try here. He specializes in thin woods for crafters.
https://www.richardscraftwood.com/
Charley
Mickeyfolse likes this.
Central North Carolina
CharleyL is offline
post #3 of 8 (permalink) Old 03-25-2019, 08:48 PM
difalkner's Avatar
First Name: David
When I built the cross for our church I resawed both the Walnut and Curly Maple down to about 1/4" for some pieces and 5/16" for others. The boards were 7" to 9" wide and about 7' to 8' long. I ran them through the planer to clean up a bit and then through the drum sander for final thicknessing.
How wide can you resaw a board?
David
sreilly likes this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #4 of 8 (permalink) Old 03-25-2019, 10:43 PM
gdonham1's Avatar
First Name: Guy
I have had problems with thin boards warping and cupping. I would recommend paper backed veneer if that is practical for your project. Trying to get thin boards flat enough to use can be problematic. Veneer with a paper back is stable and easy to adhere. You can also get the psa type of veneer but that can be really hard to position before some little part sticks and you have a hole ripped in the veneer trying to get that little spot unstuck.
I know Woodcraft caries wider veneer rolls. You can also internet order and get what ever species you want.
Good Luck
gdonham1 is offline
post #5 of 8 (permalink) Old 03-26-2019, 06:45 AM
difalkner's Avatar
First Name: David
If you plan on going the veneer route, check with Certainly Wood in NY. I've been buying from them since they opened in the 80's and they often have thicker veneers available.
David
David
Romans 3:23
post #6 of 8 (permalink) Old 03-26-2019, 07:45 AM
sreilly's Avatar
First Name: Steve
I was going to suggest resawing as well but it sounds like you have some choices on thicker veneers.
sreilly is offline
post #7 of 8 (permalink) Old 03-26-2019, 10:38 AM
First Name: Art
Do a search for door skins in whatever kind of wood you want.
mgmine is offline
post #8 of 8 (permalink) Old 03-26-2019, 03:53 PM Thread Starter
First Name: Mickey
Thank you all for the help. Looking stone of the suggested sites now. And ive also found my preferences at Ocooch hardwoods. I prefer 1/8” for my projects.
Thanks again!
Cribbage Boards rrrun CNC Routing 16 12-12-2018 12:03 PM
Router bits for Mortise and Tenon project? windhollowfarm Router Bits - Types and Usage 267 08-29-2018 11:19 AM
Christmas Gifts - End Grain Cutting Boards vchiarelli Show N' Tell 21 12-15-2016 06:45 PM
Tenons on long rails (boards) Drosner General Routing 18 09-19-2016 01:46 PM
Edge Joining Boards patlaw General Routing 26 03-21-2016 03:39 PM
