Wooden dam for cutting ceramic tile - Page 2 - Router Forums
 45Likes
post #11 of 28 (permalink) Old 05-13-2019, 09:16 AM
ger21's Avatar
First Name: Gerry
Originally Posted by RainMan 2.0 View Post
Brian, I wish I had a cnc router table right now . Not sure if itís possible, but Iíd like to have these mosaic tile blend in with the main tile . But Iíd say this is an impossible cut for tile , but if I had the tile in a water dam system with a small diameter tile bit , I think it might work .
Then thereís making the vector
You could do that easier with a tile saw. You just make all of the parallel cuts, and snap off the "fingers".
RainMan 2.0 likes this.
Ger
www.cncwoodworker.com
ger21 is offline
post #12 of 28 (permalink) Old 05-13-2019, 09:24 AM Thread Starter
RainMan 2.0's Avatar
I have a dewalt wet saw . You know I may just experiment, and just try making several parallel lines . May be a bit meticulous, but Iíll give it a try .
Great idea Gerry
Ok ,I never insulate
RainMan 2.0 is online now
post #13 of 28 (permalink) Old 05-13-2019, 07:11 PM
A ring of plumbers putty makes a good dam too. Some diamond bits can be used without water but it depends on what ways used to bond the diamonds with. With wall tiles a Rotozip with carbide tile bit works slick but it won’t work on floor tiles which are much harder.
post #14 of 28 (permalink) Old 05-13-2019, 07:14 PM
I've seen Brian and his wife's mosaic's first hand; they've done a LOT of them! Pretty amazing; i wouldn't have the patience.
(Did I mention that they're big?)
Herb Stoops likes this.
DaninVan is offline
post #15 of 28 (permalink) Old 05-13-2019, 09:11 PM Thread Starter
I’m just assuming you’d get a better life out of the cutter as opposed to dry ?
The set I bought were pretty cheap, so I thought it may be a good idea to help them along . I need to cut two 2-3/4” holes , and possibly more if I screw up . I have this feeling they get you threw once and that’s it .
Ok I just read the info on amazon , and it says to use water . So I guess I’ve got the right idea , but perhaps overkill
https://www.amazon.ca/gp/product/B01...?ie=UTF8&psc=1
post #16 of 28 (permalink) Old 05-14-2019, 09:05 AM
First Name: Gary
Just use a wax ring (toilet seal) for a doughnut seal, fill with water when using diamond core bit.
gmercer_48083 is offline
post #17 of 28 (permalink) Old 05-14-2019, 09:46 AM
window putty is better/easier...
not nearly the mess either...
jj777746 likes this.
post #18 of 28 (permalink) Old 05-14-2019, 10:39 AM
mimac's Avatar
First Name: Brian
Latex Caulk is real easy. Takes a second to install, sticks well, no rolling in the hand to form a bead, holds enough water for drilling. and wipes off with a rag with a swipe. The water drains away when the cut is through and the caulk is wet and wipes of easily.
DaninVan and jj777746 like this.
mimac is online now
post #19 of 28 (permalink) Old 05-14-2019, 09:12 PM Thread Starter
I have duct seal also, it’s very similar to plasticine. I could have easily rolled it into a dam and stuck it on there . Maybe this was a dumb idea lol
Actually I have to cut an outside section off one tile , so my contraption will work good for that
kp91 likes this.
post #20 of 28 (permalink) Old 05-14-2019, 09:20 PM
kp91's Avatar
First Name: Doug
Press-seal, duct-seal, monkey-poo.... call it what you want, that stuff has 10,000 uses
RainMan 2.0 and jj777746 like this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
Routing Ceramic and Porcelain Tile The Hobbyist CNC Routing 39 05-10-2015 11:28 PM
Wooden Tile Table Top Herb Stoops Show N' Tell 16 12-01-2014 10:57 AM
