Wooden dam for cutting ceramic tile - Page 3 - Router Forums
 45Likes
post #21 of 28 (permalink) Old 05-14-2019, 10:28 PM
Originally Posted by RainMan 2.0 View Post
Iím just assuming youíd get a better life out of the cutter as opposed to dry ?
The set I bought were pretty cheap, so I thought it may be a good idea to help them along . I need to cut two 2-3/4Ē holes , and possibly more if I screw up . I have this feeling they get you threw once and thatís it .
Ok I just read the info on amazon , and it says to use water . So I guess Iíve got the right idea , but perhaps overkill
https://www.amazon.ca/gp/product/B01...?ie=UTF8&psc=1
I have a 4 1/2Ē diamond disc for an angle grinder that was advertised as wet or dry. It would be pretty hard to use wet. I canít believe how much stucco, brick, block, and rock itís cut so far and itís still going. I think it mostly depends on what the diamonds are brazed on with and how high a temperature it can stand. Diamonds can get red hot and that doesnít seem to affect them. If the instructions say use water then do it. If the bits are made to cut glass then the water may be to keep the glass from shattering due to uneven heating.
jj777746 likes this.
post #22 of 28 (permalink) Old 05-15-2019, 12:06 AM
" If the bits are made to cut glass then the water may be to keep the glass from shattering due to uneven heating."
-Charles
Maybe keep the silica dust under better control as well. Don't need to be breathing that stuff!
DaninVan is offline
post #23 of 28 (permalink) Old 05-17-2019, 12:46 PM
TenGees's Avatar
First Name: Paul
In the sign business I saw several people cutting mirror, glass and tile using the method Brian mentioned. They put a donut of what looked like plumbers putty around the hole and filled it with water.
TenGees is offline
post #24 of 28 (permalink) Old 05-17-2019, 02:46 PM Thread Starter
RainMan 2.0's Avatar
That would work great ,with one exception, mosaics . I just thought about this,and it would be tough to seal all the small cracks between the little tiles .
I think my idea should work great for that application
TenGees likes this.
Ok ,I never insulate
RainMan 2.0 is online now
post #25 of 28 (permalink) Old 05-19-2019, 10:04 AM
Country: South Africa
First Name: Biagio
For a one-off, cut a piece of foam rubber (sponge) to fit inside the cutter, then soak it in water and cut away.
Cherryville Chuck likes this.
Biagio is offline
post #26 of 28 (permalink) Old 05-19-2019, 11:46 AM Thread Starter
Well I tried it yesterday and it worked awesome . Actually better than anticipated,as I had to line the bit up with the felt marker line I traced ,so I could see it clearly.
Also I cut kerdi board templates , and Iím going to tape them to the tule as a guide and see how that works , as opposed to guiding the hole saw to the felt marks.
I should have taken video, as it certainly has no shortage of water cooling as itís swirling around the bit
TenGees and Herb Stoops like this.
post #27 of 28 (permalink) Old 05-20-2019, 10:58 AM
TenGees's Avatar
First Name: Paul
Looking good, Rick.
RainMan 2.0 likes this.
TenGees is offline
post #28 of 28 (permalink) Old 05-20-2019, 12:12 PM
Originally Posted by mimac View Post
Latex Caulk is real easy.
Butyl rubber works better than latex...
but putty is still the least mess and waste...
Herb Stoops likes this.
Routing Ceramic and Porcelain Tile The Hobbyist CNC Routing 39 05-10-2015 11:28 PM
Wooden Tile Table Top Herb Stoops Show N' Tell 16 12-01-2014 10:57 AM
