Dewalt 625e Router speed control bypass - Router Forums
post #1 of 8 (permalink) Old 08-21-2019, 03:30 AM Thread Starter
Default Dewalt 625e Router speed control bypass
I have a Dewalt 625e Router with variable speed control on it. I want yo bypass the speed control and run directly off the mains supply. Can anyone help please.
shropshireboy is offline
post #2 of 8 (permalink) Old 08-21-2019, 07:13 AM
RogerPowys's Avatar
First Name: Roger
Send a message via Skype™ to RogerPowys
Can't think why you would want to do that. At max speed setting the motor is pretty well directly connected to the mains supply anyway, except maybe for circuitry intended to protect the motor from overload. My guess is you won't squeeze any extra speed or power from your router, and might cause it harm - so why bother?
RogerPowys is offline
post #3 of 8 (permalink) Old 08-21-2019, 07:58 AM
RogerPowys's Avatar
First Name: Roger
Oh and you'd lose the soft-start facility and probably invalidate your warranty too. Sorry seems a bad idea all round.
post #4 of 8 (permalink) Old 08-21-2019, 07:18 PM
Nickp's Avatar
First Name: Nick
Usually this is done when it fails...are you planning to use an external speed control for some reason...?
Sounds like you've got something in mind...
Nick
Nickp is offline
post #5 of 8 (permalink) Old 08-26-2019, 02:46 AM Thread Starter
The speed control unit has failed but I dont need it anyway. I just want the thing to rotate at whatever speed it happens to be.
post #6 of 8 (permalink) Old 08-26-2019, 11:22 AM
Nickp's Avatar
First Name: Nick
Can't give you specific wire configuration but what you want to wind up with is hot coming in from the cord would go to the switch...then from the switch to the hot brush...the other brush wire would go to AC return/common back to the cord.
But before you proceed, please continue your research to try and find specific wiring changes for the 625...and verify what I've described to make sure you don't fry the router or, worse, yourself...
When you bypass the speed controller the router will fire up at full speed (check your specs)...this means you will not be able to operate any bits greater than 1" or so...check router speed charts to make sure you're not spinning up too big a bit...for example, you will/should not slap on a panel bit...
Nick
Nickp is offline
post #7 of 8 (permalink) Old 08-26-2019, 11:27 AM
post #8 of 8 (permalink) Old 08-27-2019, 02:25 AM Thread Starter
Thankyou very much for your help.
