Shop A/C Filtering - Router Forums
 2Likes
  • 2 Post By CharleyL
post #1 of 2 (permalink) Old 10-13-2019, 07:57 AM Thread Starter
sreilly's Avatar
First Name: Steve
Default Shop A/C Filtering
There was a thread back some time ago about installing A/C in a shop and I advised that using pleated filters would be advisable and far better then what they come with. In this post by Jay Bates he shows his approach to the issue where he has a few thru the wall units (like hotels) and his method to properly filter the air thus protecting the unit and keeping it from needing servicing every month. See https://jayscustomcreations.com/2019...split-filters/ This apporach can/should be used for window units as well. Keeping the evaporator coil (indoor coil) free of sawdust and dirt will allow the unit to work properly, last way longer (years) and save money by working more efficiently and longer. Just make sure to do block the discharge air into the room. If you find the unit freezing up it's likely either restricted air (dirty indoor coil) or a fan issue.
sreilly is offline
post #2 of 2 (permalink) Old 10-13-2019, 01:43 PM
CharleyL's Avatar
First Name: Charley
I've been putting 12 X 20 X 1 pleated furnace filters between the cover and evaporator coil of my 22, 000 btu window style heat pump for about 15 years now. I discovered early on that this size filter would fit inside the plastic cover and completely cover the evaporator coil, and I have been using them ever since. It serves as my shop air cleaner as well as heating and cooling source. When I'm active it the shop and making lots of fine saw dust, it can fill quite quickly and require changing. I usually blow them out with compressed air a few times and then replace them, since I buy the more expensive pleated ones with the largest filter surface area.
Charley
MEBCWD and TenGees like this.
Central North Carolina
CharleyL is online now
