Making zero clearance insert for plate for table saw - Router Forums
 38Likes
post #1 of 24 (permalink) Old 11-22-2019, 05:45 PM Thread Starter
RainMan 2.0's Avatar
Default Making zero clearance insert for plate for table saw
Now I have to wonder why this never dawned on me . I’m watching this guy build a sled for his table saw ,when later on in the video he makes a zero clearance plate .
For whatever reason I never thought to use the factory plate as a template , duh!
Is this the standard way of doing it and I’m not paying attention ?
@7:00
Ok ,I never insulate
RainMan 2.0 is online now
post #2 of 24 (permalink) Old 11-22-2019, 05:50 PM
ain'ja reading the how to posts here Rick..
JFPNCM, Gaffboat and DesertRatTom like this.
post #3 of 24 (permalink) Old 11-22-2019, 05:50 PM
Yes. The template I mean
Make a bunch (4 - 6).
DaninVan is offline
post #4 of 24 (permalink) Old 11-22-2019, 06:00 PM Thread Starter
For some reason I don’t recall seeing using the factory insert as a jig . Gotta start paying attention ,but being autistic it’s tough some days
post #5 of 24 (permalink) Old 11-22-2019, 06:47 PM
That's what I do. I add a couple of drops of hot melt glue to a piece of mdf and stick em together and then either use a pattern or flush trim. My unisaw takes a fairly thick insert and it has set screws to level it with the top. The mdf threads just fine for the set screws and there is enough friction in the threads to keep them turning in use. I made about 6 last time I made some. Then when I use them I write in felt tip on the underside which blade and whether I used stabilizers etc. If you were making zero clearance for a dado set you could have one for every width stack you use.
Ray Y, Web Shepherd and jj777746 like this.
post #6 of 24 (permalink) Old 11-22-2019, 07:26 PM Thread Starter
Iím liking the hot glue idea . Never thought of that one
post #7 of 24 (permalink) Old 11-23-2019, 08:41 AM
First Name: Ray
I do the same as Cherryville Chuck except I use double-stick tape. I also tap the holes for the leveling screws in 1/2" plywood.
RainMan 2.0 likes this.
Ray Y is offline
post #8 of 24 (permalink) Old 11-23-2019, 03:11 PM Thread Starter
Well I really have to build some next spring ,as I’ve had problems with small parts falling in the arbour .
Mine has a little pin in the front to hold it in place I believe . Will have to see if that’s necessary or not.
Probably build me one of those sleds to
DaninVan likes this.
post #9 of 24 (permalink) Old 11-23-2019, 03:15 PM
Yes, it is. It stops the plate from lifting, getting caught by the blade and firing it back at you.
DaninVan is offline
post #10 of 24 (permalink) Old 11-23-2019, 03:17 PM Thread Starter
Well maybe I need a scanner and a 3D printer
jj777746 and 1fizgig like this.
