Cutting a Groove/Making Matching Piece - Page 2 - Router Forums
 4Likes
post #11 of 11 (permalink) Old 12-13-2019, 11:02 AM
Attach your workpiece to a backer strip or push block. That way when you push it past the router bit you'll greatly reduce or eliminate tearout. Routing end grain is really prone to tearout. You can make your pusher block so that a clamp can be used to hold your work to it. The clamp helps prevent the tearout more and well as making the work feed more stably past the bit and gives you something to hold onto. You can see what I mean by going to post #11 in this thread: https://www.routerforums.com/jigs-fi...r-table-2.html
