Cutting a Groove/Making Matching Piece - Router Forums
 4Likes
post #1 of 11 (permalink) Old 12-12-2019, 04:01 AM Thread Starter
Default Cutting a Groove/Making Matching Piece
Hi guys,
I had explored this in the past.I was wanting to take a 3/4" straight bit and cut a groove 3" long in a flute.I make wooden flutes. So it 3/4" wide by 3" long by 1/4" to 1/2" deep. It would be just when you stop the router....having a radius or curved end on both ends of the groove...I am good so far up to this point....I want to make a piece to fit as perfectly as possible into the groove.It would be glued in place. How do I do this? Thanks a bunch in advance!!!
Flutemaker is offline
post #2 of 11 (permalink) Old 12-12-2019, 04:38 AM
cut a floating tenon to fit and slice or cut off the length the tenon to your happiness...
treat this as an inlay such as a butterfly/bowtie..
and extreme jig to do this would be a Leigh FMT Pro...
you could make your own jig...
to make a floating tenon it takes nothing more than a piece of stock to size and a bullnose or half-round bit
jj777746 likes this.
post #3 of 11 (permalink) Old 12-12-2019, 06:26 AM
Nickp's Avatar
First Name: Nick
It sounds like you have the groove already and want to perfect-fit a piece into the groove...?
Trying to picture what that would look like...can you supply a picture...?
MEBCWD and Stick486 like this.
Nick
Nickp is offline
post #4 of 11 (permalink) Old 12-12-2019, 01:20 PM
MEBCWD's Avatar
A picture of what you want to do would really help us help you
MEBCWD is offline
post #5 of 11 (permalink) Old 12-12-2019, 07:02 PM Thread Starter
This would be a modification .I havent done it yet but think I will try it. Stick pretty much gave me the idea of how to make what I need ...cutting the floating tendon .
post #6 of 11 (permalink) Old 12-12-2019, 07:03 PM Thread Starter
Thanks "Stick".I have never cut a tendon but guess it is a good time to learn.
post #7 of 11 (permalink) Old 12-13-2019, 01:08 AM
Cutting the groove I think you already have figured out. I think it's getting the ends rounded that maybe has you stumped. If you are making a bunch of these I would make a long rounded tenon style piece like Stick suggested and then use a 3/8" radius bull nose (same curve as your straight bit) to round the ends and then cut slices off it the thickness you need.
post #8 of 11 (permalink) Old 12-13-2019, 02:57 AM
no bullnose or half round???
use a 3/8'' round over and your RT...
post #9 of 11 (permalink) Old 12-13-2019, 04:26 AM Thread Starter
Yeah I have the groove figured out...I just cut 3/4" groove or slot the length needed and stop.It will be rounded on the ends .I need to make a piece to fit into this groove.It is actually to make a repair where something didnt go like it was supposed to. Thanks !
post #10 of 11 (permalink) Old 12-13-2019, 05:21 AM
here's an image of a loose/floating tenon...
you can do the tenon in end or long grain...
Cherryville Chuck likes this.
