Bending boards made , but a horizontal router would have helped - Page 3 - Router Forums
 46Likes
post #21 of 24 (permalink) Old 05-10-2020, 08:53 PM
TWheels's Avatar
There are several horizontal router table construction projects on YouTube. One is a Stumpy Nubs (James Hamilton) :
Another, similar to one I fantasize building is an Izzy Swan project:
RainMan 2.0 likes this.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #22 of 24 (permalink) Old 05-11-2020, 06:15 AM
Wildwood's Avatar
Country: South Africa
First Name: Rob
For those that are interested, this is the end-on view that Biagio asked for, showing the pivot point of the plate, on the left, and the small arc slot and tightening knob on the right. The height adjustment bolt turns in a block of wood attached to the plate, and the end of the bolt contacts a metal plate attached to the carcass.
MEBCWD, swarfmaker and RainMan 2.0 like this.
Wildwood is offline
post #23 of 24 (permalink) Old 05-11-2020, 10:11 AM
Basically the same method of height adjustment I used except that I took an angle bracket and drilled and threaded it instead.
Wildwood likes this.
post #24 of 24 (permalink) Old 05-11-2020, 11:58 AM Thread Starter
RainMan 2.0's Avatar
Thanks Rob I didn’t realize it pivoted , and I don’t know why I couldn’t have thought of that . As I mentioned I’m really liking the simplicity of the design, and it would do the job I want perfectly.
Also I could easily attach a feather board to stop the board from trying to lift .
Should be able to get a very clean cut this way.
Just took a closer look at the first pic and noticed the tenon . What a great way to make tenons .
I may have to make a more permanent version of this with a mitre slot
Ok ,I never insulate
RainMan 2.0 is online now
