Using laser for marking electrical boxes - Router Forums
 32Likes
post #1 of 12 (permalink) Old 08-06-2020, 06:09 PM Thread Starter
RainMan 2.0's Avatar
Default Using laser for marking electrical boxes
Me smart!
Guys I had a theory on cutting holes in the right spot when your drywalling a shop .
I do have a magnetic system that works , but I’m wondering why I never thought of using my tile laser to mark the spot where to cut .
I’m going to use 3/4” plywood on two of my walls , and I’d prefer not to make a mistake when cutting out the outlets .
What I’d like to try is what you see in the first pic . The laser level sits on its tripod and you set it up till it indicates the horizontal and vertical positions of the outlet .
I’ll hold the plywood in position and then air nail a jig for my router to follow .
I used my magnetic system on mdf in my gym , and I got super accurate holes with my router .
It may be a slower process , but it’s not by the hour . Btw I’m familiar with the lipstick and carbon paper route
kp91, difalkner, MEBCWD and 4 others like this.
Ok ,I never insulate
RainMan 2.0 is online now
post #2 of 12 (permalink) Old 08-06-2020, 06:51 PM
First Name: Dennis
Hereís an idea - measure how high the outlets are mounted, write it down then make markings on the floor to position the studs. Voila, no need for lasers and/or magnets ! And if itís plywood, patching it up is ez pz anyway.
Sent from my iPhone using Tapatalk
kp91, Barry747, MEBCWD and 2 others like this.
qulevrius is offline
post #3 of 12 (permalink) Old 08-06-2020, 06:58 PM
But that is not Hi-Tech enough. Cut them out with a router? Oh I almost forgot this is the router forum.
kp91, MEBCWD, MYB and 3 others like this.
Herb Stoops is offline
post #4 of 12 (permalink) Old 08-06-2020, 06:59 PM
First Name: Dennis
CNC that **** !
RainMan 2.0 and Herb Stoops like this.
post #5 of 12 (permalink) Old 08-06-2020, 07:10 PM Thread Starter
Here’s an idea - measure how high the outlets are mounted, write it down then make markings on the floor to position the studs. Voila, no need for lasers and/or magnets ! And if it’s plywood, patching it up is ez pz anyway.
You’ll never get it close to within a rickameter that way . FYI , a Rickameter is one bizzilionth of a meter
CNC that **** !
That would be ideal . Take a 3D scan of the wall first , then transfer it to the cnc for cutting
kp91, MEBCWD and MYB like this.
post #6 of 12 (permalink) Old 08-06-2020, 07:26 PM
Originally Posted by RainMan 2.0 View Post
Youíll never get it close to within a rickameter that way . FYI , a Rickameter is one bizzilionth of a meter
I think you better send back the CNC you got before you open the box and get a 12'X12' one.
RainMan 2.0 likes this.
post #7 of 12 (permalink) Old 08-06-2020, 11:42 PM
3/ 4" plywood?! You just won the lottery? You're still in 'insulation avoidance mode'.
Another Summer almost gone by by and no progress...
For the umpteenth time, you can't do anything until that garage/shop is M.T.
The laser is perfect for leveling the boxes...or measure DOWN from the ceiling. The floor has a slope built in. (1/8" perft. +/- )
Herb Stoops likes this.
DaninVan is offline
post #8 of 12 (permalink) Old 08-07-2020, 12:23 AM Thread Starter
Itís been so hot itís impossible to work in there , +35 . Been mostly working on my beer gut
MEBCWD, Danman1957, MYB and 1 others like this.
post #9 of 12 (permalink) Old 08-07-2020, 10:34 AM
37 or 38 outside and 24 inside in late afternoon. Morning starts out at 18 or 19. I go in my shop to get away from the heat. "Just sayin" Rick. I keep the doors shut to slow the heating process.
Danman1957 and Herb Stoops like this.
post #10 of 12 (permalink) Old 08-07-2020, 01:44 PM
Rick, you are going to do the insulating first, right? Before you put up the ply, right? Putting up the ply without insulation is a complete waste of time and effort. And don't forget to up up a layer of radiant barrier beneath the insulation, it will help and boost the R value by 4 points without adding much thickness.
I take it that the laser is on a tripod for something solid so it won't move. Working on the insulation will help with the weight if you don't do the un beer able at the same time, and come winter, you'll work off calories in the shop.
