box joint jig plans - Router Forums
post #1 of 9 (permalink) Old 01-24-2011, 05:55 PM Thread Starter
John9465's Avatar
Smile box joint jig plans
What plans are available using standard drill bits for jig key and set up?
John9465 is offline
post #2 of 9 (permalink) Old 01-25-2011, 04:22 AM
xplorx4's Avatar
First Name: Jerry
Greetings John and welcome to the router forum. Thank you for joining us, and remember to have fun, build well and above all be safe.
Lamentations 3:22-23
xplorx4 is offline
post #3 of 9 (permalink) Old 01-25-2011, 09:53 AM
gav
Country: Croatia
First Name: Gavin
Hmmm, not sure of what you're asking. Can you explain more as to what you want to do with the drill bits when using a box joint jig.
gav is offline
post #4 of 9 (permalink) Old 01-25-2011, 01:20 PM
Ralph Barker's Avatar
First Name: Ralph
I'm confused by the "drill bit" aspect, too. Most box-joint jigs use either a square indexing pin, made of wood or brass, that is the same width as the router bit being used, or a finger-style template where the spacing is based on a particular size of router bit.
- Ralph
Ralph Barker is offline
post #5 of 9 (permalink) Old 01-25-2011, 03:10 PM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the RouterForums John.
Dave
the "Doctor"
Dr.Zook is offline
post #6 of 9 (permalink) Old 01-27-2011, 12:27 AM
G'day John
Welcome to the router forum.
Thank you for joining us.
Do you mean to use a drill bit as the index key for the box joint jig?
Sydney, Australia
jw2170 is offline
post #7 of 9 (permalink) Old 01-27-2011, 02:07 AM
First Name: Calie
Smile
welcome to the forum!
caliec is offline
post #8 of 9 (permalink) Old 03-07-2011, 05:26 PM Thread Starter
John9465's Avatar
Thanks for the response. I am hoping to use a standard drill bit for my index pin and distance to index pin. I know I have the brass bars of varying size as well as can make wood pins of various woods. However I thot????? maybe I could use something usually more on hand than making a special bar or trip to the drawer for the brass bar.
John9465 is offline
post #9 of 9 (permalink) Old 03-07-2011, 07:09 PM
Hi John
The drill bits way should work just fine
Another Box Joint Jig curiousgeorge Jigs and Fixtures 9 01-07-2011 07:44 PM
Box Joint jig info rpoulson Jigs and Fixtures 10 08-20-2010 01:17 PM
Cut both box joint pieces at once? Fretts Jigs and Fixtures 2 06-15-2010 02:17 PM
Bj's box joint jig steveo Jigs and Fixtures 1 02-12-2008 08:49 PM
Adapting Bob's Box Joint Jig to a Rockler Table fibertech Table-mounted Routing 8 04-23-2006 12:35 AM
