Dennis... good catch on the live edge wood. A good deal of the wood sold up at Horizon is sold live edge. Actually, originally this is what I wanted. My original plan was to use the sapwood on the outside edges of the armrests and headrest, then on both outter edges of the seat. Unfortunately once I started to mill things up, I began to find a good deal of hair line checks in the sapwood. So as it stands right now, I may go with a glueup between halfs with either a maple or walnut to give the rocker a little more flare.
As for the curves, Sometimes ya gotta go with what they got *L*. All four boards had a good curve to em. All four boards were consecutive from the same tree. All of this was factored into the price of the wood when I came to terms with the seller.
There is good and bad to buying wood like this, you can save a bit on bf costs because the mill has spent less time milling the wood square...the bad is you can run into alot of 'hidden' defects if you don't do a proper inspection of the wood. These boards have a very minimal amount of pitch, pith isn't a issue and not a knot to be found. Figure is consistent throughout the set. A good size check on one end *pictured*..and a few checks in the edges that run only a few inches, found one that ran a little under 6"s and I'll be able to work around that.
This mill offers both live edge and milled 4S.. just depends on what you want. Live edge has become quite a popular medium to work with of late. When pricing out the boards, they take into account any defects that might appear, checks, knots, pith etc. and make allowences. Typically milled 4S is the norm. Thats what I go with,, this project was a exception.
The old craftsman hybrid...
she's been a solid performer over the years. and I do put it to the test quite often. This 10/4 cherry pushes its limits...I"ve done 12/4 maple and thought I was going to burn her up *L*...ya gotta know you limits I suppose..but all in all, for the money, a great saw.
Please keep the posts coming. I'm sure you will attract a large following. I was surprised to see the wood came with bark and I noted quite a curve in one of the pieces. When I buy raw wood it is roughly squared up so it's easier to figure how much is needed and the cost. Is it common to buy wood this rough in your area or is this unique to that mill? Do they factor out the curves in pricing?
I have the same model table saw as you. I quite like it.
