Charging Station Power Strip Question - Router Forums
post #1 of 13 (permalink) Old 12-25-2014, 07:30 PM Thread Starter
MT Stringer's Avatar
Default Charging Station Power Strip Question
I am in the early stages of designing a charging station that will sit on top of an end table (another new project).
I am looking for a power strip, such as a rack mount that I can use...prolly 16 inches or less in length.
I would prefer outlets on the front and back. The reason being, I would like to plug the power cord into the back side (inside the charging station) so I can fold up the extra cord, and rout it to the laptop. The transformer would sit inside the cavity. The front outlets would be for charging various devices like phones, games, etc., especially when the grand kids come over. :-)
If you know of such an animal that doesn't cost an arm and a leg, please let me know. I would appreciate it. I really don't need more than 4-6 in the front and a couple in the rear.
Note: My project is subject to design changes...maybe even on the fly as I go.
MT Stringer is online now
post #2 of 13 (permalink) Old 12-25-2014, 08:35 PM
RainMan 2.0's Avatar
Mike we use crazy lengths of power strips all the time on our communications racks but I've never seen double sided ones?
I'd have to ask the headend guys what it is we use exactly
Ok ,I never insulate
RainMan 2.0 is offline
post #3 of 13 (permalink) Old 12-25-2014, 08:43 PM
wire mold makes one...
some assembly required and you cut to the length you desire...
Plugmold Multi-Outlet Strip, Ivory, V20GB506 | by Legrand
post #4 of 13 (permalink) Old 12-25-2014, 08:51 PM
boogalee's Avatar
First Name: Al
Hi Mike
The problem with power strips is when you plug in a transformer it covers another plug in.
They make longer strips that would cure this problem but they are expensive and probably not fit your project. I have never seen a double sided strip.
If you want cheap then:
harbor freight power strip
Al B
boogalee is online now
post #5 of 13 (permalink) Old 12-26-2014, 07:17 AM
waynecochran's Avatar
First Name: Wayne
I don't if this would help but, google quirky.com. they make a flexible power strip.
waynecochran is offline
post #6 of 13 (permalink) Old 12-26-2014, 07:27 AM
Nickp's Avatar
First Name: Nick
How about something like this back to back...?
Thunderdog DX64SP 6 Outlet Surge Protector, 6 Protected Outlets, 4 Ft. Power Cord, 1080 Joules Surge Protection, 40 dB EMI/RFI Noise Filtration
...or this...side by side and then rotate the outlets...?
http://www.amazon.com/Side-Socket-Ou.../dp/B0054K90IY
Pigtails are also available for the transformer plug-ins...
http://www.amazon.com/1-Foot-Extensi...power+pigtails
Nick
Nickp is online now
post #7 of 13 (permalink) Old 12-26-2014, 07:35 AM
Mike ..
you want the power strips in 120V or USB ports??? Both???
found these..
Ivory Compact, double-sided power strip
Electronic Accessory Charging Dock : Mount the power strip
Amazon.com: Power Strips: Tools & Home Improvement
post #8 of 13 (permalink) Old 12-26-2014, 08:46 AM
kp91's Avatar
First Name: Doug
Mike, you could actually install outlet boxes, 2 facing inside and one facing outside. You could use the combo USB and std receptacles to get the outlets you desire.
If you use the "new style" receptacles they are easy to make wood covers for to give the front of your box a clean look
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #9 of 13 (permalink) Old 12-26-2014, 10:59 AM
That's sort of what I did in my gym Doug . I made a template because I needed to be accurate with the boxes I wanted to use for these posts
post #10 of 13 (permalink) Old 12-26-2014, 11:59 AM Thread Starter
Thank you all very much. The vast (and unpaid) research department has come through again.
I have several options that y'all have suggested.
Rick, I like your adaptation suggested by KP91.
I looked at the other links also. While browsing, I found one outlet strip I like -> 7 Outlet 10' Surge Protector (1250 Joules)
It has everything I could ask for in a power strip
  • Multiple outlets
  • 2 USB charging ports
  • Ten foot power cord with a right angle plug
The right angle plug would work great since the outlet is in the middle of the wall and behind the couch.
That would take care of the outside outlets. I suppose I could install a metal box on the inside with an outlet for the laptop. As you are probably aware, the power for the laptop just plugs in with a standard power cord. Then there is the power supply (or whateveritiscalled!). That thing gets warm. So I plan to vent the rear so heat can escape. This project kinda looks like a cigar box, huh? :-)
I am still open to any and all ideas.
Thanks for the suggestions.
Peak HP dgcutter General Routing 22 01-10-2013 08:23 PM
Opinions?: Shop Heaven Power Question BigJimAK DIY and Renovation 9 06-24-2012 01:07 AM
Buying second router for router table. Question on power rating Chris_L Table-mounted Routing 8 01-06-2012 04:15 PM
Router Power Question jsilvia General Routing 5 02-12-2008 09:08 PM
