Mitered Box Back - Router Forums
 2Likes
  • 1 Post By Seldonman
  • 1 Post By DonkeyHody
post #1 of 4 (permalink) Old 02-01-2015, 08:07 AM Thread Starter
Seldonman's Avatar
Default Mitered Box Back
I have build a small approximately 9" X 9" mitered box that is open in the front and into which I slide three small drawers to hold K-Cup coffee packs. I have made one already and I used plywood for the case and back. Now I am making another out of solid maple for the mitered case. Question, should I use a solid maple back or just birch plywood. I am giving this to my Aunt who lives near San Francisco and I am afraid the back might expand and push the case apart. Is this a legit concern? What is your recommendation?
Thanks,
Jim
ksidwy likes this.
Seldonman is offline
post #2 of 4 (permalink) Old 02-01-2015, 08:50 AM
DonkeyHody's Avatar
First Name: Andy
Jim, I think you have a legitimate concern. Many years ago, I built a bookcase with a solid back. I thought I could restrain the movement by just gluing it to every shelf. The back split down the middle the first winter. For a box as small as that, the movement should be less than 1/8". Why not use a solid panel and let it float in dados with a little slack on the width? Good luck.
ksidwy likes this.
DonkeyHody is offline
post #3 of 4 (permalink) Old 02-01-2015, 09:20 AM Thread Starter
Seldonman's Avatar
Thanks I thought about doing that but unfortunately, I glued up the case yesterday. My only option now is solid or plywood back. Probably go with plywood as it is safest, with my sincerest apologies to Mr. Greene and Mr. Greene!
Jim
post #4 of 4 (permalink) Old 02-01-2015, 11:54 AM
RainMan 2.0's Avatar
I have a lot to learn as I never thought that could be an issue. What about a synthetic material on the back instead now seeing as it's glued. That puck board is real cheap that you buy at windshield places
RainMan 2.0 is online now
More fun with box joints Gaffboat Show N' Tell 17 04-07-2015 09:27 PM
box joints? mah New Member Introductions 6 12-30-2012 10:48 PM
box corner joinery almost there Jigs and Fixtures 17 10-15-2012 08:08 AM
Attaching Hinges To A Jewelry Box Jerry Bowen Tools and Woodworking 16 07-10-2012 05:11 PM
First Box Joints w/a Hart Design Jig Wild Rag Jigs and Fixtures 2 03-23-2009 08:54 AM
