Table Saw Infeed Table Extension - Router Forums
 18Likes
post #1 of 15 (permalink) Old 04-21-2015, 06:13 PM Thread Starter
MT Stringer's Avatar
Default Table Saw Infeed Table Extension
I hope to be able to use my Incra Miter Gauge to cut some pieces for an upcoming project that will require 20 inch cross cuts. Currently, the max I can cut safely crosscut is about 12 inches.
I browsed the internet for ideas, then commenced to draw my version of the extension.
The attached drawings show my saw table top (27 x 48), the 3 inch x 3 inch angle iron with the 3 inch x 1 3/4 inch steel tube attached. The fence slides on the steel tube.
The new extension table will be about 24 inches wide x 11 - 12 inches deep. I will attach it by using at least one Rockler Universal Fence Clamp (Item #31373), and maybe a second one. I will have to figure that out later.
I don't want to, but if I have to, I can position a roller stand to support the extension.
The main part of the table will be about 1 inch thick. That should be easy to make since I have some 1/2 inch Baltic birch. The two support pieces will be attached with screws. I have a piece of Formica that just might be wide enough to cover the top.
My main concern is to make the extension easy to attach and remove.
Your thoughts and ideas appreciated.
Name:	Table Saw Infeed Table Overview.jpg
Name:	Extension Details.jpg
MT Stringer is offline
post #2 of 15 (permalink) Old 04-21-2015, 08:31 PM
First Name: Jerry
Mike,
You sure do have my attention. I am currently working on cedar chest lid. It is 23" x 43" x 3/4" and made of four boards joined together with splines. After the glue up, the lid had to be trimmed to the 43" width. As you noted, very cumberson on my TS which is of the same dimensions.
H have the the Incra Express Sled and the fence for my Incra V27. The set up is not a good arrangement for a 23" cross cut especially one of the length of the lid. Made the cuts with great care, both ends, one to clean up and the other to my desired width of 43".
I'd like to make more chests in the future but do not look forward to the trimming to width as described above.
I have been giving thought to something like you are describing and is why your thread has my attention. I will be following your progress.
Do you not have the fence with the extention for your miter gauge? For myself, it is a necessity when crossing cutting to an exact dimension.
Keep up the good fight/work.
Jerry
Jerry Bowen is offline
post #3 of 15 (permalink) Old 04-21-2015, 08:40 PM
DonkeyHody's Avatar
First Name: Andy
Can I sell you on the idea of a crosscut sled? I built one that can crosscut 26 inches.
We should be careful to get out of an experience only the wisdom that is in it and stop there lest we be like the cat that sits down on a hot stove lid. She will never sit down on a hot stove lid again and that is well but also she will never sit down on a cold one anymore. - Mark Twain
DonkeyHody is offline
post #4 of 15 (permalink) Old 04-21-2015, 08:49 PM Thread Starter
Thanks. I have one also but I am getting a lot of use out of the Incra Miter Gauge.
post #5 of 15 (permalink) Old 04-21-2015, 09:01 PM Thread Starter
@ Jerry - "Do you not have the fence with the extention for your miter gauge?"
Yes sir. I didn't include it in the drawings because the miter gauge drawing bogged the drawing down with all the detail in it. I downloaded the miter gauge from the Trimble 3D Warehouse. Someone did a great job of creating it. I was just happy to be able to draw the piece of angle iron to exact size.
I had to go look. I have the Incra 1000 HD. And as you are well aware, when you draw the miter gauge back, sometimes the fence extension drops off the table. That is where the aggravation comes into play. I am going to try to remedy that little problem.
The table extension will also make it easier to use my sled simply because it will add some support to what normally hangs over the saw table when I set up for a cut.
post #6 of 15 (permalink) Old 04-21-2015, 09:30 PM
vchiarelli's Avatar
First Name: Vince
Mike:
Looks like your on the right track with your design. I've attached an image I found but won't/can't post a link - it takes you to "Ted's Woodworking Plans" - you don't want to go there.
Vince
MT Stringer likes this.
vchiarelli is offline
post #7 of 15 (permalink) Old 04-21-2015, 09:34 PM Thread Starter
Thanks. I saw that also. I managed to "Save As" and capture the image. I hate Ted and the horse he rode up on!
That's where I got the idea for the clamps, which I already have on hand to attach a sacrificial fence when using the dado stack.
post #8 of 15 (permalink) Old 04-22-2015, 06:35 AM
MYB
First Name: Mark
I have been wanting to do the same for a long time so I'll be interested to see your results. If you don't want to buy clamps here's a way to make your own - https://atelierdubricoleur.wordpress.com/?s=fence+clamp
MYB is online now
post #9 of 15 (permalink) Old 04-22-2015, 10:25 AM
I'm going to make one of these. Mostly I do cabinets but would like to make some chests as well. I think it would be a good idea to have the rail underneath, on the outside of the saw's front rail, be adjustable so the clamps apply uniform pressure to the saw's rail. Not quite sure how to make that solid, but I think with an aluminum front rail on the saw, I don't think its a good idea to clamp directly to the metal. Any thoughts, or do you just make the fit very tight?
DesertRatTom is online now
post #10 of 15 (permalink) Old 04-22-2015, 11:53 AM
First Name: Jerry
I sure know about the extention dropping down as you mentioned. I bet that all of the interest in the issue we will come up with some answers. You sure have started a good thread and will get lots of "like".
Table Saw extension wing router table w/shop built lift pdiesel75 Special Needs Woodworking 12 03-31-2015 08:31 AM
Extension Table And Fence Jig For Drill Press Gaia Jigs and Fixtures 23 07-28-2012 06:27 PM
Craftex Sliding Table Saw Attachment CX200S CanuckGal Tool Reviews 6 07-02-2012 10:19 AM
Finished my table saw extension router table. magicman Table-mounted Routing 42 06-04-2012 04:46 PM
Continuing Discussion of Table Saw Extension garybaritone Table-mounted Routing 8 03-01-2009 12:24 AM
