Equilateral triangle as a box - need some guidance - Router Forums
 26Likes
post #1 of 38 (permalink) Old 04-23-2015, 07:24 PM Thread Starter
JFPNCM's Avatar
First Name: Jon
Default Equilateral triangle as a box - need some guidance
I searched the forum on this project but was not able to find any examples. if there are, then please redirect me accordingly.
SWMBO has requested a triangular (equilateral) shaped box which should not be a problem. However, she did not like the exposed "end grain" at the corners in the first model I built. So, I'm seeking guidance on laying put the cuts to avoid the end grain.
For the model I used a 3/4 x 10 x 10 inch piece of scrap fir as follows:
1) Set the TS blade to 30 degrees and ripped one edge of the piece. I then flipped the board over to rip the 2nd edge on the opposite side of the piece. As a result the 2 angles are opposites.
2) Ripped the board into 3 strips each 3" wide.
3) The result was a very nice equilateral triangle except for the end grain.
Perhaps I shouldn't have flipped the board over prior to making the second rip but that seemed logical at the time to make a 60 degree angle for the joint.
Suggestions will be appreciated.
Jon
JFPNCM is offline
post #2 of 38 (permalink) Old 04-23-2015, 07:31 PM
each cut @ 30°...
face the end grain...
no flipping pieces over...
rotate them 180° end for end to make the end cuts...
post #3 of 38 (permalink) Old 04-23-2015, 09:40 PM Thread Starter
JFPNCM's Avatar
First Name: Jon
each cut @ 30°...
Got it, thanks. Thought that might have been the error. Now if I could just figure out why I thought "flipping" the piece was in order.
Jon
JFPNCM is offline
post #4 of 38 (permalink) Old 04-23-2015, 11:13 PM
somebuddy around here says there is a senior moment afoot...
and from what I gather it's the senior moment's fault...
so be on the look out...
rcp612 likes this.
post #5 of 38 (permalink) Old 04-24-2015, 01:35 AM
Jon, look up some posts on flag cases.. They may give you some idea, especially the ones by Xplorx4...
Sydney, Australia
jw2170 is offline
post #6 of 38 (permalink) Old 04-24-2015, 06:21 AM
Nickp's Avatar
First Name: Nick
It's called P.A.Y.S. - Pre-programmed Advanced Youth Syndrome...
It's going around...
Nick
Nickp is offline
post #7 of 38 (permalink) Old 04-24-2015, 06:29 AM
Originally Posted by Nickp View Post
It's called P.A.Y.S. - Prue-programmed Advanced Youth Syndrome...
what happened to CRAFTS???...
(Can't Remember A Farthing Thing Syndrome)...
rcp612 and jj777746 like this.
post #8 of 38 (permalink) Old 04-24-2015, 06:41 AM
DonkeyHody's Avatar
First Name: Andy
I've been doing this for a while. I'm an engineer, so I'm "supposed" to have some intuitive understanding of spatial relationships. But I've made just about every mistake there is to be made when dealing with angled cuts. I'll even have it all drawn up in 3-D, but when I get to the tablesaw, I tend to lose track of "up" and "down" It gets some better with experience, but I think I'll quit making such mistakes when I'm looking up at the grass.
DonkeyHody is offline
post #9 of 38 (permalink) Old 04-24-2015, 06:55 AM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
Actually I am making something very much like this right now, to be honest I am making 50 of them as I never make one of anything, I will post the results later. N
jj777746 likes this.
neville9999 is offline
post #10 of 38 (permalink) Old 04-24-2015, 06:23 PM Thread Starter
JFPNCM's Avatar
First Name: Jon
Gentlemen:
I appreciate the input and definitely enjoyed the humor as well.
Unfortunately, I am still at a loss as to how to avoid the end grain showing on the corners. I followed Stick's instructions and when I assemble the model I still have end grain. Clearly I'm missing a step here.
The flag boxes are great, thank you for the suggestion James and I may well end up going that route.
Jon
JFPNCM is offline
cut off bin to box to planter to--? JFPNCM Show N' Tell 12 08-27-2019 12:30 AM
My first box dkneifel Show N' Tell 19 02-08-2016 08:10 AM
Learning How to Make a Tissue Box Cover learnexperience General Routing 2 12-05-2011 05:56 PM
Another combination plane blade box hack rwyoung Show N' Tell 8 01-10-2011 08:41 PM
Beall Tilt Box Versus Wixey Angle Gauge bennybbc Tool Reviews 4 02-04-2010 12:01 PM
