Tilting laundry hamper - Router Forums
 5Likes
  • 5 Post By Gaffboat
post #1 of 8 (permalink) Old 05-17-2015, 06:09 AM Thread Starter
Wildwood's Avatar
Country: South Africa
First Name: Rob
Default Tilting laundry hamper
I need to make a pair of tilting laundry hampers, somewhat on the lines of the attached picture - but the hampers must be able to be simply lifted out, for cleaning the cavity from time to time.
Can anyone point me to a plan for the hinging arrangement that will enable this?
Wildwood is offline
post #2 of 8 (permalink) Old 05-17-2015, 10:35 AM
Gaffboat's Avatar
First Name: Oliver
Two ideas come to mind, Rob. The first would be to make a hinge similar to the way an oven or dishwasher door works. The hinges have a long bar that the door slides over so the bar is inside the door. The door can be opened normally or pulled up when open to slip if off of the hinge bar.
A simpler approach would be to use a cabinet bolt in the side of the cabinet at the bottom to serve as a pin the hamper can pivot on to open. The pivot hole in the stile of the hamper has an open bottom that allows the hamper to be removed if necessary by pulling it up off of the pivot pin. The sketches show the concept easier than I can describe it.
Gaffboat is offline
post #3 of 8 (permalink) Old 05-17-2015, 02:39 PM
Al B Thayer's Avatar
First Name: Al
Ive tackled this problem before by just building it so it tilts and lifts out. Did work but I did not like the way it worked. By the time you get the back side cut down enough to tilt and get everything working properly. I found it just wasn't worth the trouble.
A hamper that slides out on "drawer slides" works better and you have more capacity. I made the front just like a cabinet door.
Al
The best things in life, aren't things.
Al B Thayer is offline
post #4 of 8 (permalink) Old 05-17-2015, 03:52 PM Thread Starter
Wildwood's Avatar
First Name: Rob
Many thanks Oliver - the pivot pin is going to work well for me.
Thanks also for your input Al - I agree with you, but my customer has her heart set on the tilting hamper.
Rob
Wildwood is offline
post #5 of 8 (permalink) Old 05-18-2015, 08:53 AM
First Name: Art
Here is a built in one that could just as easily be a stand alone cabinet. It is 35" high with the top door being 9".
Name:	cloths bin 001.jpg
Name:	cloths bin 002.jpg
mgmine is offline
post #6 of 8 (permalink) Old 05-18-2015, 09:24 AM
Garyk's Avatar
First Name: Gary
Try Winfield for plans, they specialize in such items. Most of the woodworking magazines have online plans & indexes now. Stay away from that crook advertizing thousands of plans real cheap, he's a crook and has copied copyrighted plans. He's also in a country that looks the other way on such things.
Garyk is offline
post #7 of 8 (permalink) Old 05-18-2015, 09:58 AM
Really nice and simple design. I'd cut out some openings on the top to act as handles when lifting it out. I'd also make the front and back panels with wicker inserts so there would be some air flow. Dirty clothes get stinky fast without air flow. I'd also make it with half inch ply and cutouts on the sides with wicker so it doesn't get too heavy for an older person to lift.
post #8 of 8 (permalink) Old 05-25-2015, 03:10 PM Thread Starter
Wildwood's Avatar
First Name: Rob
Thanks everyone for the good advice.
Wildwood is offline
Tilting Router Lift Marcel M Project Plans and How To 0 09-14-2012 04:25 PM
Tilting arbor router table? martrix Table-mounted Routing 12 08-21-2012 05:13 PM
Laundry Room Cabinets Thread hands made for wood Show N' Tell 10 04-13-2011 09:41 PM
Laundry Sink Project TRN_Diesel Show N' Tell 15 03-22-2009 12:01 PM
Laundry Sink Project TRN_Diesel Show N' Tell 2 03-09-2009 12:28 PM
