Miller dowels as drawbore pegs - Router Forums
 2Likes
  • 2 Post By Mike
post #1 of 5 (permalink) Old 06-20-2015, 01:58 PM Thread Starter
First Name: Larry
Default Miller dowels as drawbore pegs
I'm working on a project that has loads of M&T joints, and was thinking of adding drawbore pins--then I spotted my Miller Dowels and am wondering if I couldn't use them as drawbore pins (certainly finished better than hand chopped). What do you think? Or for that matter, what about regular dowel stock?
luxlarry is offline
post #2 of 5 (permalink) Old 06-20-2015, 05:33 PM
What is a Miller Dowel?
Herb Stoops is offline
post #3 of 5 (permalink) Old 06-20-2015, 05:36 PM
Either way will work Larry.
Herb, they have steps cut in them and come in different sizes. They have matching drill bits for making the holes. Another bonus is you can buy them in different woods to contrast or hide joints.
Name:	Miller dowels.jpg
old55 and Herb Stoops like this.
post #4 of 5 (permalink) Old 06-20-2015, 05:42 PM
OH Yeah, I've seen those,never used them but I have talked to woodworkers that really like them.
Larry, I wonder how the shoulderd would work in a draw pin situation. A tapered dowel would work better, I would think. Try it on a scrap joint and find out though, maybe you are on to something.
post #5 of 5 (permalink) Old 06-21-2015, 04:54 PM Thread Starter
First Name: Larry
Thanks Herb. I want something that will really hold. The M&T joints are in the side/end frames for a folding futon bed, and the pins would stop the forces on the M&T from working loose--would seem to be much stronger with a drawbore pin or the Miller dowels.
larry
luxlarry is offline
Drilling into ends of small dowels Gaffboat Tools and Woodworking 21 04-01-2014 06:42 PM
A Question About Using Dowels Jerry Bowen Tools and Woodworking 15 02-09-2014 01:07 PM
Drill Bit Size For 10mm Dowels Gaia Tools and Woodworking 8 07-10-2013 06:45 AM
Drilling into dowels with ZenBot Dennis Burges CNC Routing 5 04-08-2013 08:37 PM
Finishing shaker pegs Qstick The Finishing Touch 7 02-27-2007 03:27 PM
