A better way to store clamps - Router Forums
 97Likes
post #1 of 147 (permalink) Old 08-02-2015, 11:47 PM Thread Starter
RainMan 2.0's Avatar
Default A better way to store clamps
Guys I improvised and it drove me crazy as I had to clamp the clamps to the wood for storage . It was kind of a hassle getting them in and out so I'm trying to build something a little better .
This is what I was doing to get by
So for the new attempt I dadoed out a slot in a piece of wood to hold a 1/2" piece of mdf in tightly . Got this idea from you guys when I seen this done to make consistent box joints
So I secured the wood to my GI miter gauge at 2-1/2" as that seemed like a fairly good space to provide room for enough for each clamp to sit by each other .
I increased the size of the dado stack by a few thousands so that I could lift the 2/6 off and on easily as I dadaod each slot . This is the coolest idea I've seen for consistency
So here it's held up temporarily to see if it will be a viable idea
I'm thinking about maybe attaching a 2/4 vertically to the back of this 2/6 to secure it to the wall .
The slots are 1/2" wide and I'm almost thinking I should have gone a little thinner ,but the clamps appear to sit in there so so .
I'm going to cut this one and instead of going behind the drill press I'll build two seperate ones around it .
Anyone have any thoughts to improve upon a clamp storage rack as I don't really know of any other way to go about this ?
mapmaker2, Ray H, ksidwy and 3 others like this.
Ok ,I never insulate
RainMan 2.0 is offline
post #2 of 147 (permalink) Old 08-02-2015, 11:52 PM
JFPNCM's Avatar
First Name: Jon
Looks good but will they fit after you insulate? Not an excuse but the way.
old55 likes this.
Jon
JFPNCM is offline
post #3 of 147 (permalink) Old 08-03-2015, 12:20 AM Thread Starter
Yes no issues there
old55 likes this.
post #4 of 147 (permalink) Old 08-03-2015, 12:23 AM
Rick , just out of curiosity would you try turning the clamps around 180* and then see if the clamp (both jaws) will sit on top of that board without falling off? I clamp my small ones to a 1 x mounted under my bench like you are doing, minus the grooves, but unclamping them and then reclamping them back onto the board is becoming a PITA. If they will sit in a groove like that it would save a lot of time. Or maybe the answer is to mortice a bunch of rectangular holes in a board like that and then I could just slide them into the holes. Thanks, you got me thinking.
post #5 of 147 (permalink) Old 08-03-2015, 12:27 AM Thread Starter
Charles I turned them around and they didn't sit as well , kinda sat there precariously .
I'm thinking about making the slots a little tighter . It's no real hardship to start over as this is kind of a test.
I was going to start on my work bench drawers but accessing the clamps is really getting on my nerves so I want to address this first before I proceed .
Should be a fairly simple project I hope .
old55 likes this.
post #6 of 147 (permalink) Old 08-03-2015, 06:53 AM
Here's an article showing several different racks to make, depending on what you're trying to store. I have many more as it seems that the various magazines are always running articles on clamp storage.
I have the problem of not having enough wall space to hang the racks, and bought this Pack Rackģ Clamp & Tool Storage System - Rockler Woodworking Tools which is kind of a compromise. The thought was that the rack could be rolled to where I was working so that the clamps would be at hand but my "assembly area" usually winds up where the motorbike lives and the rack is on the opposite corner of the shop and not easily rolled over sometimes. One of the drawbacks to the design is that some of the clamps fall off easily, particularly pipe clamps - Rockler now makes sheet metal racks for specific types of clamps that bolt to the frame to address this, I may have to look into them at some point.
ksidwy likes this.
tomp913 is offline
post #7 of 147 (permalink) Old 08-03-2015, 07:16 AM
chessnut2's Avatar
Nice going, Rick. Nicely photographed, and nicely documented. I've gotta do that.
jw2170 likes this.
chessnut2 is offline
post #8 of 147 (permalink) Old 08-03-2015, 09:28 AM
Nickp's Avatar
First Name: Nick
My struggle with clamp storage left me with several boxes that suit the different sizes. The boxes keep the clamps stored upright so not a lot of wall or floor space is taken. They sit in a corner until I need them. My short ones (6", 12") are in small canvas tool bags...they pile on each other easy enough. Also lets me be portable...
Nice job, Rick...I think if I had the wall space I would copy your design...like it...
Nick
Nickp is offline
post #9 of 147 (permalink) Old 08-03-2015, 10:34 AM Thread Starter
Charles your idea would work for me with the Bessey clamps but I can't turn the Irwins around as there handles get in the way . I'm going to dado on less deep and a little narrower and call it a day . I think it will be much better than what I was doing
post #10 of 147 (permalink) Old 08-03-2015, 10:44 AM Thread Starter
Charles,
Ross aka as Old55 showed me an interesting pic and there's a ridge at the front so they don't slide off . That would be easy enough to dado in and would work great for the Irwins . And maybe if I try your idea the Besseys would work to . Gotta hit the shop and see
The more I think about it I suspect it's not going to work with the Besseys as I can't go any deeper with my dado slot , and they would need to be pushed back further to fall into place , but I think I'll dedicate one rack for the Irwins and one for the big K clamps
Low cost banding clamps JAOB Tools and Woodworking 7 04-26-2015 06:20 PM
Pipe Clamps MT Stringer Tools and Woodworking 15 04-22-2015 08:36 AM
Making Clamps Easier to Use MT Stringer Show N' Tell 17 09-01-2014 02:03 PM
Toggle Clamps (Update) Pop_pop1 Table-mounted Routing 1 08-29-2005 06:52 AM
T Track Toggle Clamps Pop_pop1 Table-mounted Routing 4 07-29-2005 02:22 AM
