Connecting three table tops together. - Router Forums
 6Likes
post #1 of 20 (permalink) Old 08-21-2015, 05:17 PM Thread Starter
Default Connecting three table tops together.
Here is my plan I'm not a wood working an and really don't know much. I am making a desk but buying most of it individually through ikea.
Everything should line up correctly but if you looked at the picture you'd notice 7 blue spots and 2 green spots.
Blue = Table Top legs I will buy
Problem... Green is gonna be some brackets but I don't know what brackets. There are suppose to be legs there to hold the table tops up but instead I wanna put some type,of bracket there instead of legs to have leg room. i need to know what bracket I should use? I found this ( can't post URL it's called a solid brass table keeper from Rockler )but don't know if it's the correct thing I want. My goal,is to make it some don't have to put a leg where the green spots are and make sure it doesn't bend down so it feels like one big desk instead of three separate ones.
DarkBlade2117 is offline
post #2 of 20 (permalink) Old 08-21-2015, 05:17 PM Thread Starter
I would post links to the exact parts but can't post them until 10 post.
post #3 of 20 (permalink) Old 08-21-2015, 05:51 PM
RainMan 2.0's Avatar
His reminds me f my old computer desk . It was something like IKEA I believe but I liked how it was two pieces instead of three . The centre was the cut point and it was connected with a piece of particle board underneith . The sides were storage
Ok ,I never insulate
RainMan 2.0 is offline
post #4 of 20 (permalink) Old 08-21-2015, 05:52 PM
Guest
I surmise you intend this to be a desk/computer table. If it were me, I'd put diagonal braces under the points where your green dots are. The wide part of the brace should be right under the desktop and span from the wall to about 8 inches from the front edge of the desktop. The narrow part, of course, should be on the floor and span about 8-10 inches from the wall. If you wanted to be fancy, you could cut an arc instead of a straight line from top to bottom. Either should give you adequate knee and toe room and hold the top rigidly enough to carry the weight of the desktop, the computer and other things that may be there.
I see there are legs along the back edge but it might also be necessary to install a ledger board under the back edge of the desktop to fasten it to the wall.
DaninVan likes this.
163481 is offline
post #5 of 20 (permalink) Old 08-21-2015, 05:57 PM
I found a pic of my old desk to give you an idea . You can't really see the centre where the cut is though . I love corner desks as I find there more ergonomic
DarkBlade2117 likes this.
post #6 of 20 (permalink) Old 08-21-2015, 06:03 PM
How about having an Aluminum extrusion frame welded up? Say 2" sq. tubing, into a double 'L' shape?
The problem is (as I see it) we have no idea of what the underside looks like. Is it one contiguous flat surface, or are there frame pieces in the way?
Screwing up into the underside of the top is really risky...you might come through the top face! And probably not all that strong either.
That's why I suggest the one piece welded frame. If the legs are attached to the frame, you could have a party on it.
Is it going into a corner (two adjacent walls)? You could add a tremendous amount of support by having the back edges resting on wood ledgers/cleats, attached to the walls.
DaninVan is online now
post #7 of 20 (permalink) Old 08-21-2015, 06:07 PM Thread Starter
It's all one flat surface on the bottom
post #8 of 20 (permalink) Old 08-21-2015, 06:10 PM Thread Starter
Looked up,diagonal brace and a few things came up. Could you link me to what you are talking about? I know the dimensions if needed.
Edit- Pictures just showed up
post #9 of 20 (permalink) Old 08-21-2015, 06:17 PM
Seriously?! No crosspieces anywhere? You are either very lucky, or not! There should be something to add stiffness to the tops...
What are the tops made from; solid wood or particle board of some type? How thick are the top?
If the tops are solid laminated boards of 1" or thicker, than you just might have won the lottery.
post #10 of 20 (permalink) Old 08-21-2015, 06:29 PM Thread Starter
IKEA has kindda a do it yourself desk but I'm doing a modded do it yourself.
I can find out material but it's 1 3/8 inch thick
Converting a Bosch RA1180 to a table LagunaPaul Table-mounted Routing 31 08-11-2014 09:45 PM
Ready made Router Table Tops BeauxTi Table-mounted Routing 2 08-04-2012 11:20 AM
Custom Ellipical Poker Table AzViper Show N' Tell 29 01-21-2012 02:41 PM
For Sale: RS 500 Router Table - routertabledepot.com sheridan Woodworking Classifieds 1 08-20-2009 09:51 AM
