sanding blocks - Router Forums
 66Likes
post #1 of 21 (permalink) Old 08-24-2015, 04:11 PM Thread Starter
PhilBa's Avatar
First Name: phil
Default sanding blocks
Recently, I took a finishing class and was reminded how important good sanding blocks are. The nice ones go for $20 (preppin weapon, for example). I want to have lots of blocks with different grits and at $20 a pop that adds up fast. There are lots of cheapo and, IMO, not that usable ones for low prices. So, I decided to make my own. After looking at various ideas on the internet, I decided to design it myself, too.
Key requirements:
- must fit in my hand comfortably (I gots da ar-tha-ritus)
- must hold the sandpaper tightly
- must use 1/4 of a standard sandpaper sheet
- must be easy and quick to load paper
After a few tries, I came up with the design shown in the first 2 pictures. I used a rockler cam clamp (2 for $10) and designed it so when you close the cam, the sandpaper tightens up. You can get 4 strips from a standard sandpaper sheet. I was concerned about the cam lever being uncomfortable on my hand. That didn't turn out to be the case for me but if it bothers you, turn the sanding block so the lever points forward.
Materials:
  • wood - any scraps will do. you can use pine/fir or hardwood. 2x4 stock would be ok. The base dimensions are critical to fitting a 1/4 sheet strip.
  • Rockler 1/4"-20 cam clamp. part number 58244. Other cams will work but adjust the width of the dado.
  • 1/4"-20 2" bolt or screw.
  • 1/4" washer.
  • cork or rubber matting for the bottom of the base.
Next 2 pictures show the base and clamp block measurements. edit: clamp block diagram is wrong. See later post for correct picture.
The next set of pictures show the steps in making the sanding block.
  • Cut the blanks for the base and clamp.
  • Route out the base tray for the clamp. The clamp block needs to be a little loose in the tray. Start with it too tight and sand the ends of the clamp block when assembling.
  • Route out the groove for the cam lever in the clamp
  • Drill the holes in the following order: drill a pilot hole through both blocks (hold together with blue tape or a clamp to ensure alignment), drill out the 3/8" hole for the bolt/screw head (verify depth, the head must be at least 1/16" recessed) and then drill the 1/4" hole through both base and clamp.
  • Route the round over ends of the base using a 3/8" round over bit. Use a backing block to prevent tearout.
  • Cut the rounded surface of the clamping block. If you don't have a bandsaw, you can use a large round over bit in the router to ease the edges. The clamp block needs to feel comfortable in your hand.
  • Sand, sand, sand. Hold it in your hand - sand off any sharp edges. Think comfort. Ease the edges of the hole on the bottom of the base.
  • If you want a softer base, add the cork or rubber matting to the bottom of the base.
  • Now is a good time to tune the clamp block. Sand the ends of the clamp until the gap between the clamp and tray is slightly less than twice the thickness of the sandpaper you are going to use.
  • Use a 2" 1/4-20 screw, insert through both base and clamp. Hex bolts aren't good because they are hard to tighten. Screw the bolt into the cam. Close the cam and tighten the bolt so it's finger tight. The thickness of the sandpaper will make it tighter. When the cam is open, you should have about a 1/16" gap between the base and the block.
The last 3 pictures show putting sandpaper in it. I use the edge of my table saw to tear the sandpaper but there are plenty of ways to do it. Slip one end of the strip between the clamp and base, wrap the strip around the bottom and slip the other end of the strip between the clamp and the block. Lay the sanding block on a flat, clean surface, use your fingers to pull both ends tight and close the cam. The clamp should pull the strip tight and you are ready to sand.
Name:	block 2 3d.png
Name:	block 1 base.png
Name:	block 1 clamp.png
ropajeki, berry, rcp612 and 21 others like this.
Visit my shop website.
PhilBa is offline
post #2 of 21 (permalink) Old 08-24-2015, 04:12 PM Thread Starter
PhilBa's Avatar
First Name: phil
Some people prefer a sharper end on the their sanding blocks so here are a couple of alternative approaches to the base.
Name:	3 alt bases.png
PhilBa is offline
post #3 of 21 (permalink) Old 08-24-2015, 04:18 PM
Stick486 is offline
post #4 of 21 (permalink) Old 08-24-2015, 05:53 PM
RainMan 2.0's Avatar
Really neat idea Phil ,looks like they turned out really well . Great idea with the clamp
OPG3 and PhilBa like this.
Ok ,I never insulate
RainMan 2.0 is online now
post #5 of 21 (permalink) Old 08-24-2015, 05:55 PM
schnewj's Avatar
Sweeeeeet!
I know what's going on my project list...
Thanks, Phil
schnewj is offline
post #6 of 21 (permalink) Old 08-24-2015, 06:53 PM Thread Starter
PhilBa's Avatar
First Name: phil
Dang, posted an old picture for the clamp. The cam lever dado really needs to go the full length of the block. Here's the correct one:
OPG3 likes this.
PhilBa is offline
post #7 of 21 (permalink) Old 08-24-2015, 11:08 PM
I like the fact that you can custom tailor the design and edges to what you want . One of the neater ideas I've seen
OPG3, old coasty and PhilBa like this.
post #8 of 21 (permalink) Old 08-24-2015, 11:11 PM
vindaloo's Avatar
First Name: Angie
Another good project with text explanation and images to assist. Thanks.
OPG3, ksidwy and PhilBa like this.
When everything around you is going to pot, get out in the workshop.
vindaloo is offline
post #9 of 21 (permalink) Old 08-25-2015, 05:55 AM
skiroy56's Avatar
First Name: Laurence
Great idea and very well executed.
Thanks for posting.
skiroy56 is offline
post #10 of 21 (permalink) Old 08-25-2015, 07:55 AM
Those are really nice. I can see both sharp edged and round being very useful. Saving this post for a pretty-soon project. Thanks for sharing that.
ksidwy, PhilBa and preacher like this.
Sanding Disk Storage MT Stringer Show N' Tell 29 07-14-2015 10:55 PM
Edge Band Sanding Blocks MT Stringer Jigs and Fixtures 6 04-22-2015 03:26 PM
Sanding BernieW Woodturning and Lathes 9 12-29-2011 07:01 PM
How To Finish Sanding Moulding Of Door? Gaia The Finishing Touch 8 01-11-2011 02:32 PM
Sanding Tips pmspirito Tools and Woodworking 7 05-22-2009 08:49 AM
