Making a wood 'donut' - Router Forums
 28Likes
post #1 of 15 (permalink) Old 09-04-2015, 05:38 PM Thread Starter
Gaffboat's Avatar
First Name: Oliver
Default Making a wood 'donut'
For my latest project I needed a 4" diameter circle with a 3" diameter hole in the middle out of 3/4" stock. The outside edges of the 'donut' or ring also needed a 1/4" round-over on the front and back.
Hole saws would have worked for a job like this but I don't have the correct sizes so I used the router. There's nothing special here, but if you're new to routing this might help you see one way of making something like this simply, safely, and relatively quickly.
The photos tell the story but here's what I did:
1. Drilled a 1/4" hole for the router circle guide pivot in the center of my 5.5" x 5.5" piece of cherry.
2. Drilled and counter sunk holes for screws in two corners, plus two within the inside diameter to attach the stock to a backup board. The screws keep the stock from slipping and turning, One set keeps the waste in place and the other set keeps the circle blank in place when the bit finally plunges through the 3/4" stock.
3. With the blank stock screwed to a backup board and the board clamped to the table I used a circle jig to cut the outside of the circle with 1/4" spiral bit making multiple passes.
4. Once the cut was finished I unscrewed and removed the outside waste.
5. With a 1/4" round-over bit in my trim router I rounded over the edge, unscrewed the circle, flipped it over, re-attached it to the backup board and rounded over the other edge.
6. Then, I unscrewed the circle blank from the backer, put some double-sided tape close to the outside of the final shape and reattached everything to the backer board. The tape holds the final donut in place when it breaks free from the center.
7. With the diameter reset on the circle jig I cut the inside diameter. Then it was a simple matter of unscrewing the center waste and pealing the donut off of the backer board.
As I said, nothing special here, just a simple no-hassle way to make what I needed.
Gaffboat is offline
post #2 of 15 (permalink) Old 09-04-2015, 05:56 PM
thanks....
Stick486 is offline
post #3 of 15 (permalink) Old 09-04-2015, 06:57 PM
kp91's Avatar
First Name: Doug
No sprinkles or Icing? At least it's a cherry doughnut.
A good looking torus and a great tutorial as always!
RainMan 2.0 likes this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #4 of 15 (permalink) Old 09-04-2015, 07:20 PM
TwoSkies57's Avatar
As always Oliver, you lead the pack...
Skipper the Penguin
TwoSkies57 is offline
post #5 of 15 (permalink) Old 09-04-2015, 07:44 PM
old55's Avatar
First Name: Ross
Nice Oliver.
Ross,
old55 is offline
post #6 of 15 (permalink) Old 09-04-2015, 08:20 PM
Very impressive, Oliver!
( You do know the drugstore sells soft ones, right? )
kp91, vindaloo, JudgeMike and 3 others like this.
DaninVan is offline
post #7 of 15 (permalink) Old 09-05-2015, 06:42 AM
First Name: Gary
Oliver, Great use of double sided tape. I am still working up the courage (trust) in tape for that use. Good tutorial!
gmercer_48083 is offline
post #8 of 15 (permalink) Old 09-05-2015, 07:42 AM
First Name: Roy
Oliver, thanks. Easy for us beginners to understand - and visualize - through your photos.
Gaffboat and ksidwy like this.
Roy Drake is offline
post #9 of 15 (permalink) Old 09-05-2015, 08:22 AM
chessnut2's Avatar
I've wondered how this could be done. It looks both safe and accurate. Thanks!
chessnut2 is offline
post #10 of 15 (permalink) Old 09-05-2015, 09:43 AM
kp91's Avatar
First Name: Doug
experiment on 'cheap' wood before trusting nice wood to your tape. I've had good and disastrous experiences using tape
1 John 1:9
Fredericksburg, VA
kp91 is online now
making new wood turn grey like barnwood agravation The Finishing Touch 35 08-20-2016 03:38 PM
Introduction to Wood Species... BobandRick Wood Species 40 03-19-2015 12:03 PM
New to woodworking brussell143 New Member Introductions 5 02-05-2015 08:11 AM
A Wood Experience-Contest Woodworkers Source Contests Archive 2 05-14-2009 05:58 PM
