Geometry question - Router Forums
 8Likes
post #1 of 12 (permalink) Old 10-25-2015, 04:40 PM Thread Starter
First Name: Woody
Question Geometry question
I want to make some various sized wooden knobs by drawing a circle, marking evenly spaced points around the circumference, drilling holes at those points and cutting the whole thing out on the band saw. Can any one tell me an easy way to mark those points evenly on various sized circles? Thanks in advance for your help. Woody
woody1401 is offline
post #2 of 12 (permalink) Old 10-25-2015, 05:02 PM
schnewj's Avatar
I'm not quite sure I understand what the end result is that you are looking for from your description. What do the holes have to do with the "cutting out"?
In any case, decide how many holes you want on the circumference, divide that number into 360, use a protractor to mark the points on the circumference, and your done.
360/10(holes)=36
Find the center of the circle, then mark out the points using the protractor based on the number of holes and the angles you determined.
If you are cutting the knobs out to be hexagon, septagons, octagons, etc., just connect the dots.
Hope this helped. If not post a description of the end result configuration and we may be able to get you there.
schnewj is offline
post #3 of 12 (permalink) Old 10-25-2015, 05:14 PM
boogalee's Avatar
First Name: Al
How many holes (3, 4, 5) or print this.
http://www.routerforums.com/attachme...1&d=1445807579
Al B
boogalee is online now
post #4 of 12 (permalink) Old 10-25-2015, 05:29 PM
360/10(holes)=36
Here is a pretty good video showing how the gentleman made a 5-lobe knob
The 5-lobe knob seems to be the most common. He's making a specific size. but if you want a different size, follow the procedure that he shows and adjust the dimensions accordingly. In laying out the centers of the scallops, the compass should be set to (1.176*radius) - you would have to adjust the diameter of the Forstner bit used to make the scallops and the washer used to round off the corners.
ksidwy likes this.
tomp913 is offline
post #5 of 12 (permalink) Old 10-26-2015, 12:40 PM Thread Starter
First Name: Woody
Thanks everybody. Those answers take care of my question beautifully.
Note to SCHNEWJ I want to make star knobs similar to the ones illustrated by Tromp 913
post #6 of 12 (permalink) Old 10-26-2015, 01:18 PM
old coasty's Avatar
First Name: Bob
Question. I need to make knobs with the threaded shaft fixed in the knob, rather than the knob turning on the shaft. What is the best thing to fasten the shaft to the tee nut?
old coasty is offline
post #7 of 12 (permalink) Old 10-26-2015, 01:25 PM
TenGees's Avatar
First Name: Paul
I use this to divide circles for making whirligig propellors. I center the wooden circle (hub) on the pattern and mark the edges at the number of divisions that I want (up to six). It might be useful for your application too, Woody.
http://www.routerforums.com/attachme...cledivider.pdf
firstmuller likes this.
TenGees is offline
post #8 of 12 (permalink) Old 10-26-2015, 02:00 PM
schnewj's Avatar
5 minute epoxy would probably be the best bet. Less "bulky" then the next method.
Another method is to use a carriage bolt through the top of the knob and use a nut to lock it in the underside.
schnewj is offline
post #9 of 12 (permalink) Old 10-26-2015, 02:03 PM
schnewj's Avatar
Perfect!
Great video showing how to make the star knobs. However, as a personal choice I would probably use plywood instead of particle board.
tomp913 likes this.
schnewj is offline
post #10 of 12 (permalink) Old 10-26-2015, 03:22 PM
Red Loctite is probably the easiest (less messy) way to do that.
tomp913 is offline
Hello with a router fence question nevertoosafe New Member Introductions 9 11-02-2014 03:22 PM
Question About This Forum Jerry Bowen Tools and Woodworking 4 03-30-2012 10:46 AM
New user question for dado cuts with a router pb2375 Starting Off 6 07-13-2008 05:31 PM
DC Question angus Lobby 3 03-31-2008 08:29 PM
