Glue ups. Hate 'em! - Router Forums
 45Likes
post #1 of 40 (permalink) Old 01-12-2016, 03:10 PM Thread Starter
Default Glue ups. Hate 'em!
I have come to believe that glue up is the scourge of woodworking. I would rather sand.
One question that I have is regarding squaring up during glue ups. I typically use the measurement across corners method. The thing I haven't been able to figure out is how do I get another measurement when the clamp that I'm using to tweak across the long corners is in the way? I'm probably missing something obvious but I'm good at that.
Tom
bigmuddyriver is offline
post #2 of 40 (permalink) Old 01-12-2016, 03:23 PM
vchiarelli's Avatar
First Name: Vince
Hi Tom
Trying to understand what you're doing so a couple of questions for you:
What project, how large.
How are you placing your clamps - can they be lowered away from the corner and still provide clamping capabilities as well as measurement.
Can you use the 3-4-5 method (or a smaller multiple of that) at another corner.
It would help if you could post a picture.
vchiarelli is offline
post #3 of 40 (permalink) Old 01-12-2016, 03:47 PM
gjackson52's Avatar
First Name: Gary
Would it work to dry fit the boards and then check the measurements ? I don't think the glue changes the dimensions very much ?
gjackson52 is offline
post #4 of 40 (permalink) Old 01-12-2016, 04:49 PM
Tom
on squares and rectangles use speed squares clamped to the inside corners to hold your project together...
mjadams61 likes this.
post #5 of 40 (permalink) Old 01-12-2016, 04:49 PM
if at all...
gjackson52 likes this.
post #6 of 40 (permalink) Old 01-12-2016, 05:00 PM
vchiarelli's Avatar
First Name: Vince
I think Tom is trying to check for squareness after glue up and clamping to ensure the clamping pressure hasn't pulled to project out of square. So a dry fit wouldn't help in that case cause he'd then have to take it apart to apply glue.
post #7 of 40 (permalink) Old 01-12-2016, 05:23 PM
gjackson52's Avatar
First Name: Gary
If the wood being used isn't expensive, he could always make it a bit bigger and square off after it has dried ?
Gary
TwoSkies57 and MT Stringer like this.
post #8 of 40 (permalink) Old 01-12-2016, 05:25 PM
Nickp's Avatar
First Name: Nick
I gather you're usong the clamp diagonal to tweak it...
Can you use a square or form on the outside,,,then no need to measure..
Can you dry fit, square, then mark your work surface then glue and assemble to the marks...
Nick
Nickp is offline
post #9 of 40 (permalink) Old 01-12-2016, 05:43 PM
MT Stringer's Avatar
Gary
Yep. What Gary said. The boards will inevitably move a little (dang glue!). I always glue up more stock than needed and later cross cut to the correct length and rip to the final width if it is needed.
MT Stringer is offline
post #10 of 40 (permalink) Old 01-12-2016, 05:57 PM
vchiarelli's Avatar
First Name: Vince
Gary
That would be difficult when making case goods, which I gather is why he would want to check squareness of the corners.
DaninVan and billyjim like this.
Using router for glue up Mickeyt Table-mounted Routing 26 01-18-2016 11:21 AM
Hide Glue Daikusan Tools and Woodworking 9 02-11-2014 07:47 AM
Glue Ups 1x4 x 24 3putt Lobby 5 12-29-2008 03:21 PM
Glue ups 3putt The Finishing Touch 4 12-22-2008 01:32 PM
