Speaker Stand Build - Router Forums
 2Likes
post #1 of 11 (permalink) Old 01-31-2016, 10:37 PM Thread Starter
First Name: Trevor
Default Speaker Stand Build
If the base is 1 1/2"-2" thick cherry made like the picture will that be strong enough to not worry about it breaking under the weight of 43lb speaker and the other wood parts, or should I consider a different hardwood? The center vertical part would be walnut, with the top plate cherry.
Name:	speaker stand 2.jpg
TrevortdogR is offline
post #2 of 11 (permalink) Old 01-31-2016, 10:48 PM
steel version of that wrapped in any woo og your choice would be a no worries...
providing there were absolutely no outside mitigating circumstances straight wood construction may work but why risk it???
Stick486 is offline
post #3 of 11 (permalink) Old 01-31-2016, 10:54 PM Thread Starter
First Name: Trevor
Getting tubular steel is easy and not to expensive but not sure about what it would cost getting it welded into that shape.
What about plywood as the base, would that be stronger than hardwood?
post #4 of 11 (permalink) Old 01-31-2016, 11:21 PM
First Name: Keith
Stick with your metal...you're only talking about 4 small pieces of tubing and three welds. How much can it cost?
Mig welding that lot up wouldn't take 10 minutes.
Buy yourself one length of tubing, cut it up yourself and find a local hot rodder.
cocobolo1 is offline
post #5 of 11 (permalink) Old 01-31-2016, 11:24 PM
modify the base design a bit and bolt/rivet the metal together...
cut the tube steel into angles as required and rivet into place..
Stick486 is offline
post #6 of 11 (permalink) Old 02-01-2016, 08:58 AM Thread Starter
First Name: Trevor
Why would I cut it into angles when it would be in the shape of a capital I?
post #7 of 11 (permalink) Old 02-01-2016, 09:00 AM
First Name: Keith
Why would I cut it into angles when I would have the shape of a capital I?
Stick just likes to complicate things for everyone else, that's all.
Nothing wrong with plan A.
TrevortdogR and RainMan 2.0 like this.
post #8 of 11 (permalink) Old 02-01-2016, 11:14 AM
if you need an angle bracket(s) to assemble w/ cut them from/out of a short piece of tube...
Stick486 is offline
post #9 of 11 (permalink) Old 02-01-2016, 11:16 AM
almost another success...
Stick486 is offline
post #10 of 11 (permalink) Old 02-01-2016, 11:32 AM
First Name: Keith
...we're catching on...
What to use for Speaker Cabinet? TexasGator Router Bits - Types and Usage 10 04-03-2015 03:09 AM
Speaker build - (link to a different forum) GulfcoastGuy Show N' Tell 6 06-08-2014 10:44 PM
Car speaker Flush mounting philippg New Member Introductions 15 07-11-2013 12:57 PM
A Precision-Built Speaker Box Alfreddo General Routing 9 07-06-2012 12:27 PM
transplanted from speaker building loninappleton New Member Introductions 8 07-01-2008 10:39 AM
