How To Add Mattress Support Slats to Bed Frame - Router Forums
 5Likes
post #1 of 26 (permalink) Old 03-09-2016, 06:44 AM Thread Starter
Contributor of the Month
Default How To Add Mattress Support Slats to Bed Frame
I have to add bed slats to a queen size wood bed frame per the new mattress's manufacturer's requirements. The old box spring/foundation did not require this amount of support. The manufacturer requires 5 slats. I could rest the slats on the wood ledges that are attached to the side rails but I would like the top of the slats to be level with the top of the ledges in order not to raise the mattress height. The slat length will be 58 inches and according to the sagulator a 2 X 4 with the 3 1/2" side facing up should be ok. The ledges are 1" wide and 1 1/2" tall. I'm thinking either 3" metal angle braces into the edges of the 2 X 4 and the ledge OR toe screws through the side of the 2 X 4 and into the ledge.
Any thoughts or recommendations?
JIMMIEM is offline
post #2 of 26 (permalink) Old 03-09-2016, 07:37 AM
First Name: Scott
Looks like a job for some 1/8th x 1 in. angle iron to me.
Smokindog is offline
post #3 of 26 (permalink) Old 03-09-2016, 07:59 AM
add ''buckets'' to the face of the ledgers...
a fence bracket laid over on it's side would make for a very strong connection...
''Z'' metal would work...
take the short cut..
go to your favorite big box and go to the framing connector/brackets/hardware section and look at the display...
you'll see just what it will take to get where you want to be..
MT Stringer and Herb Stoops like this.
post #4 of 26 (permalink) Old 03-09-2016, 10:27 AM
First Name: Keith
Couple of years ago I did something similar.
All I used was 1 x 6's...about 10 of them. Sat them right on the existing side supports.
Herb Stoops likes this.
OK, fess up...which one of you clowns stole my sig? It was right here a second ago.
cocobolo1 is offline
post #5 of 26 (permalink) Old 03-09-2016, 10:31 AM
the OP doesn't want the 1˝'' gain in height...
post #6 of 26 (permalink) Old 03-09-2016, 10:34 AM Thread Starter
That would be a good way to do it except that this would add 3/4" to the height of the mattress which unfortunately would be too much. Had to get a short foundation as the bed owner is short. So, I'm trying to add the slats so they are level with the side rail ledges.
JIMMIEM is offline
post #7 of 26 (permalink) Old 03-09-2016, 10:48 AM
Jim you're talking about removing the ledge and going with 2 x 4 where as Keith is talking about keeping the ledge and going with 1 x 6. There is no difference in height. You don't need 2 x 4 to support the weight. I'm 320 lbs and a few extra 1 x 4 or 1 x 6 is good enough. I did screw the slats to the ledgers just for good measure though.
post #8 of 26 (permalink) Old 03-09-2016, 02:46 PM Thread Starter
I don't want to remove the ledge. I want the top of the slats to be level with the top of the ledges. I took Stick's suggestion and found some Simpson metal supports for 2 X 4's that will do the trick.
JIMMIEM is offline
post #9 of 26 (permalink) Old 03-09-2016, 02:48 PM
oldyam's Avatar
Country: Ireland
First Name: Nigel
I think Jim was meaning to use the 2 x 4 as a central support down the center of the bed base, which is what I have just done on a recent project. I used an appropriately sized joist hanger at each end cut to suit with the narrow side up to provide better support to the 1 x 4 cross slats.
Will see if I can up load a pic later.
oldyam is offline
post #10 of 26 (permalink) Old 03-09-2016, 02:50 PM Thread Starter
Just got back from HD and they had Simpson brackets that will work. Thank You. I had gone to a HD last week but it's smaller than the HD I went to today and the stock doesn't seem to be as extensive.
Simpson FB24Z
JIMMIEM is offline
Fabric Art with Arts & Craft Walnut Frame TRN_Diesel Show N' Tell 15 07-28-2014 08:55 PM
How to Make a Decorative Picture Frame Using a Router learnexperience Tools and Woodworking 1 08-02-2011 11:47 PM
king size bed frame atmartin23 Show N' Tell 11 12-30-2009 02:30 AM
Indestructable kids bed KoLdArKnEsS Show N' Tell 4 09-11-2006 09:24 PM
