Making A Zero Clearance Table Saw Insert - Router Forums
 1Likes
  • 1 Post By Stick486
post #1 of 5 (permalink) Old 04-10-2016, 08:05 AM Thread Starter
Gaia's Avatar
First Name: Peter
Default Making A Zero Clearance Table Saw Insert
Hi all,
I'm making a zero clearance table saw insert I'll bring the blade up from under to cut the slot. Though to do this I'll need to remove the riving knife. What I'd like to know is, how do I make a continuation of the slot for the riving knife to rise?
Cheers,
Peter.
Gaia is offline
post #2 of 5 (permalink) Old 04-10-2016, 10:27 AM
Do it in two stages - cut the first slot for the blade. Put the old insert back in the table. set the new insert over the blade and move the fence over until it hits the edge of the insert. Lower the blade, slide the insert back towards you until the blade will cut the slot length you're looking for. With the insert FIRMLY clamped in place to the table, slowly raise the blade, extending the original slot.
tomp913 is online now
post #3 of 5 (permalink) Old 04-10-2016, 10:34 AM Thread Starter
Gaia's Avatar
First Name: Peter
OK thanks seems straightforward.
Peter.
Gaia is offline
post #4 of 5 (permalink) Old 04-10-2016, 10:41 AM
Originally Posted by Gaia View Post
Hi all,
Cheers,
Peter.
reinstall your old plate...
set the fence to rip the ZC plate..
rip the slot for the riving knife..
BrianS likes this.
post #5 of 5 (permalink) Old 04-10-2016, 10:46 AM Thread Starter
Gaia's Avatar
First Name: Peter
Hi Stick
Thanks,
Peter.
Gaia is offline
Fold down router table Gaffboat Table-mounted Routing 21 09-09-2018 06:41 PM
New to the forum Zwervertje57 New Member Introductions 7 06-06-2015 11:10 AM
Ryobi Intermediate table ..bushings??? rbevz Table-mounted Routing 5 02-24-2011 04:43 PM
guide to making zero clearance inserts ZCI blurry Tools and Woodworking 12 03-01-2009 11:13 PM
rousseau table insert 46_trap Table-mounted Routing 6 07-06-2007 09:33 PM
