28" Table Legs - Router Forums
 6Likes
  • 2 Post By Stick486
  • 3 Post By hawkeye10
  • 1 Post By kp91
post #1 of 6 (permalink) Old 06-17-2016, 04:18 PM Thread Starter
Default 28" Table Legs
My son wants to build a table from a solid-wood door this weekend. The legs he wants to use are available at IKEA, but they're three hours away. They want a week to ship them. What can he use for legs that would be similar to these? I thought about using 2x4s temporarily, but the back of the door/table will be mounted to the wall, and with us being novice woodworkers, the legs probably won't fit when we get them. It's a long shot, but I thought I'd ask.
Scotty: I can't change the law of physics! I've got to have 30 minutes!
patlaw is offline
post #2 of 6 (permalink) Old 06-17-2016, 04:29 PM
threaded hand rail or large diameter dowel into a floor flange w/ your choice of finial...
patlaw and Shop guy like this.
post #3 of 6 (permalink) Old 06-17-2016, 06:22 PM
hawkeye10's Avatar
First Name: Don
Go to the big box store like Lowes and have them cut and thread black iron to your liking then buy some flanges and screw them on to the door and the pipe to the flange. You now have your legs that will hold a lot of weight. At $4 a piece for the legs you want to order I would wonder if they would hold any weight.
patlaw, billyjim and Shop guy like this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #4 of 6 (permalink) Old 06-17-2016, 08:15 PM
First Name: Richard
Either of them thar guys offers a good answer.
Shop guy is offline
post #5 of 6 (permalink) Old 06-18-2016, 05:04 AM
you know w/o stretchers over time the legs won't accept torquing and the table will get flaky/shaky unless you go the brute strength method..
ie.. large diameter on their OD floor flanges relative to their ID and legs that aren't brittle or will bend/flex along their long axis.....
steel legs beat out wood and square trumps round..
faux paint the steel..
use a stiff bristle parts cleaning brushes to simulate grain when you paint lighter earth tones over flat darker earth tones..
the stiff bristles leave streaks of the flat darker earth tones showing..
base paint in an easy spiral application in several complimentary colors...
mix them up and blend one into another..
think in mild tiger stripe camo patterns...
mimic a a board that has good rays and grain ...
post #6 of 6 (permalink) Old 06-18-2016, 10:08 AM
kp91's Avatar
First Name: Doug
You could take the floor flange 1 in. Black Malleable Iron Threaded Floor Flange-521-605HN - The Home Depot idea and go fully industrial, use 6 pipe tees and connect the legs with stretchers on the short ends and one long stretcher in the middle.
Rogerdodge likes this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
Add a jig saw table to your table saw pbriggs8 Project Plans and How To 11 06-14-2016 08:16 PM
How to extend a cast iron router table? rickjb Table-mounted Routing 4 05-31-2014 09:03 PM
Designing a new Router Table Julie Table-mounted Routing 25 04-16-2013 12:36 AM
Rigid Model R2900 Router Combo and Ryobi Model A25RT02 Router table bigdave720 Table-mounted Routing 12 04-05-2012 07:27 PM
